Results 1 to 13 of 13
04-10-2007, 03:06 PM #1
- Michigan
Red- 2002 WS6 Trans Am
Need help with some upgrades for an a4
I want to add a stall. I know once you get the stall, you should get a shift kit for it. Some have said you need a trans cooler also, is this true? I was also thinking of getting different gears. Maybe a 373. Would you guys recommend this? Just looking for a good setup. Also if i get the shift kit and i shift the a4 manualy through 1 to drive, will it take away the hesitation and shift fast? Thanks guys.
Oh yea my current setup is:
BG Ram air
SLP Airbox (k&N Filter)
Smooth bellow
Pacesetter LT's and ORY
GMMG Exhaust
04-10-2007, 04:28 PM #2
- Nov 2006
- Broken Arrow, OK
A cooler is more of a priority than a shift kit with a stall. Heat is what kills automatic trannies, and stalls produce more heat. If you don't put a cooler on with the stall, you can kiss your tranny adios fairly quickly.
People with automatic trannies don't typically go bigger than 3:73s, thats pretty much the optimal gearing for an automatic.
You should avoid the manual shifting. With a stall and possibly gears, your car is going to shift fast enough for you.
04-10-2007, 04:49 PM #3
- Mar 2006
- Gulfport
red- 2000 trans am ws6
Agreed with above u can also add a deep pan for alittle extra cool insurance.
04-11-2007, 11:31 AM #4
- Michigan
Any ideas on what setup to run?
04-11-2007, 12:03 PM #5
- Mar 2006
- Gulfport
I went with a Yank 3600ss,B/M trans cooler24000,TC1 aluminum deep pan.TransGo shift. I also got 3:73 gears
04-11-2007, 01:33 PM #6
04-12-2007, 01:54 PM #7
- Michigan
04-12-2007, 01:58 PM #8
- Michigan
Oh yea one more thing, how much do you guys think a set of drag radials would run me? I have 18 by 10.5 zo6 rims in the back? I need new tires anyways lol.
04-12-2007, 02:00 PM #9
Don't forget to upgrade the clutch basket because that is a weak link... I'm using the BEAST basket with a 4600 stall, and no shift kit. Just some programming !!!
04-12-2007, 03:55 PM #10
- Mar 2006
- Gulfport
For deep pan,Trans cooler,transgo and a Yank,right at $1000.And I just got my car back today so I havent been to the track. and the drag radials prices are gonna depend on what brand u go with I went with Mickey ET streets and got them for $185 a tire 17s though.
04-16-2007, 07:19 PM #1198T/AformulaGuest
I have 17in rims and went with 555r Nitto DRs and got them for 155, but had a friend that worked there so they would have been 185...I love them btw, if your going to be doing street driving and still want the car to turn corners but hook up when your at a dead stop go with Nittos, MT are a real soft but if your only going to be driving at the track I would go with them...
04-17-2007, 07:52 AM #12
- Mar 2007
- NC
NBM- 1998Z28
Your not gonna be able to manual shift a 4L60E tranny unless you put in a manual valve body. A shift kit will allow you to stay in and gear you want to. However when you push the gear selector from first to 2nd don't expect it to shift on comand it won't happen. The E in 4L60E stands for electronic and the only thing that controls the shift points is the CPU. You need a tranny cooler not a shift kit and a good dyno tune to get all your shift points adjusted. All your gonna do is bang your rev limiter.
04-17-2007, 07:49 PM #13
The 01 &02 models have weak flexplates, you should consider replacing it with a TCI SF29 race grade unit. You have to remove 3 of the six bolts anyway to replace the TC, you might as well remove the remaing bolts as long as you are in there.
SteveC
Help: upgrades
By 2000dreambird in forum External EngineReplies: 1Last Post: 05-31-2011, 09:46 PM -
Question: 97 lt1 upgrades
By RollingD in forum LT1Replies: 25Last Post: 08-28-2009, 07:49 PM -
Possible new upgrades
By R_Yates69@Hotmail.com in forum Firebird / WS6Replies: 4Last Post: 08-31-2008, 11:28 AM -
Upgrades
By joker in forum Firebird / WS6Replies: 9Last Post: 09-13-2007, 05:00 PM -
upgrades!
By davss01 in forum New Member IntroductionsReplies: 5Last Post: 11-16-2006, 05:08 PM
