Results 1 to 10 of 10
    Junior Member 99SS711's Avatar
    Iowa
    99 Camaro SS
    Shift hesitation help please
    For a while my 99 Camaro SS has had this shift hesitation. It has the 4L60-e transmission. When you are on the throttle 1/2 to 3/4 it gets to a point where it acts like it wants to shift. Then it will rev another 200 to 500 rpm and finally shift. It does not do it if your easy on the gas, running it through the gears, or just mat it. I have had the transmission flushed 7,000 miles ago and they said everything looked good. I installed a shift kit and it did it before and after. Replaced throttle position sensor still same problem. Little help please.
    NC
    1998Z28
    I hope you aren't trying to shift your car with your gear selector knob because it won't change gears manually. The E on a 4L60E stands for electronic which means the only thing that control over what gear its in is the CPU.
    Iowa
    99 Camaro SS
    When I am running it hard I shift it manually. It will stay in what ever gear I want until I shift it. If I want it will bounce off the rev limiter all day in what ever gear I put it in.
    11's HERE I COME INIT2WIN's Avatar
    Louisiana
    2002 Camaro Z28 A4
    What Rpm does your car shit out of every gear if you mash the gas and don't manually shift it?
    Iowa
    99 Camaro SS
    If I floor it in drive it shifts at 6000 rpm.
    MOTOR CITY MARO' SSTODD's Avatar
    LIVONIA,MICHIGAN
    PEWTER
    2000 CAMARO SS #3821
    Leave it in OD and not D because it will bang off the limiter in D for some reason. The "hunting" at part throttle may be normal as it cannot figure out if you are going to "mat it" or "let off".
    Another Slow LS1 shortdog's Avatar
    St. Louis, MO
    99 Z28 A4
    Quote Originally Posted by 99SS711 View Post
    Unless you like spending money on trannys, I highly recommend leaving it in gear. 4l60e trannys aren't made for manual shifting and that maybe the reason why it hesitates when shifting.
    calif.
    With a shift kit it is a must to DELETE all of the TQ management and to set all the "shift times to "0"--otherwise it will never operate correctly and can cause pre-mature failure----
    SoCal
    Mag Red
    '98 C5
    Quote Originally Posted by tblu92 View Post
    I agree.....Removing the shift delay is also a MUST
    WI
    Blog Entries
    1
    09 EclipseGT 75 Chevy 4x4
    2001 Trans-Am 13 F-XT
    Get it tunned and stalled, then you'll be good. Add a decent tranny cooler in there too for you don't burn it up.
  1. Hesitation
    By staleycornell in forum General Help
    Last Post: 02-09-2011, 03:46 AM
  2. LS1 Hesitation?
    By GrapeApeTA in forum General Help
    Last Post: 09-27-2010, 08:02 AM
  3. Need Help, hesitation
    By ESBdieselcam in forum General Help
    Last Post: 10-15-2009, 06:07 AM
  4. Help with hesitation
    By BruceLee in forum General Help
    Last Post: 05-09-2007, 02:55 PM
  5. Hesitation
    By mcbeejw in forum General Help
    Last Post: 10-19-2006, 02:37 AM
