Thread: brand new brake rotor worn.....
04-08-2007, 07:04 PM #1Junior Member
- Sep 2005
- ft worth
I just put new rotors and pads on my wife's 2001 firebird last weekend. Today I looked at it and the rear driver side wheel is covered in brake dust and the rotor already has major grooves in it, but only the outside. The inboard side of the rotor looks good. The other three rotors are all smooth and "new" looking. I removed the tire, caliper, and rotor again to make sure everything was installed right. I did find the rubber part of the brake hose was twisted, but not kinked. It didn't appear to be enough to restrict flow. Anyways, I straightened out the brake hose and put it all back together. I thought maybe the caliper is sticking, but wouldn't it eat up both sides of the rotor and not just the outside? Any advice will be appreciated. Thanks, Ryan.
04-09-2007, 04:29 AM #2Impounded
- Feb 2007
- Pa
Red- 99 TA
one of the pins is stuck,take it apart and use anti sieze on the pins so the entire caliper can float.the reason the inside is ok is because the caliper piston is moving properly,the outside is worn because the entire caliper can't move on the pins.when ever you pull these caliper off always pull the pins,clean um and lube um.
04-09-2007, 05:34 AM #3Junior Member
- Sep 2005
- ft worth
Thanks. I have heard of this before. Anyone have a "how to" on pulling and cleaning the pins?
04-09-2007, 08:33 AM #4
I'm sure there is a "how to" somewhere,,,but if you take it apart you'll figure it out. It's easy. Once the caliper is off there are 2 more bolts to remove the caliper bracket. This bracket is where the pins are located, actually these pins are where the caliper bolts were threaded into.
If the pins are free and movable,,,it should have taken a wrench to hold the pins still (from turning) while the caliper bolts were being removed.
If you have a frozen pin,,,sometimes applying a little heat while twisting it back and forth will free it up. Just be carefull not to cook the rubber cup/seal.
Pull it out and clean it thuroughly, both the pin and it's bore. Lube it and reinstall.
04-09-2007, 08:34 AM #5
Also while it's apart, inspect the rubber cup/boot for the pin and make sure it doesn't have any splits or pin holes that will allow water to enter.
04-09-2007, 10:32 AM #6Junior Member
- Sep 2005
- ft worth
04-09-2007, 11:42 AM #7
Not a problem. They just slide in and out. Hope that helps. Larry.
04-09-2007, 01:02 PM #8Impounded
- Feb 2007
- Pa
Red- 99 TA
just to let you know when you reinstall everything you should be able to turn the rotor by hand,if you can't something is binding.i always apply the brake pedal a few times before reinstalling the wheel then try turning the rotor.if it turns with my hand its ok,if i need to use a small bar etc to turn it i start looking for problems.if you don't do this you get what you have now FAILURE to COMMUNICATE! and this is the way hes wants it,you gotta get your mind right luke.
Brake rotor rubbing
By 98RedTA in forum General HelpReplies: 5Last Post: 04-22-2014, 06:08 PM -
Help: Rear Brake Rotor
By Black Dragon WS6 in forum General HelpReplies: 3Last Post: 06-20-2009, 10:47 AM -
Help: Rotor Brand Information
By chaosinfinite in forum Camaro / SSReplies: 7Last Post: 05-13-2009, 05:46 AM -
Rotor and brake help!
By NJ2002WS.6 in forum Firebird / WS6Replies: 33Last Post: 09-13-2008, 04:30 AM -
brake pad and rotor upgrade????
By clg82 in forum Suspension and HandlingReplies: 18Last Post: 05-04-2007, 10:40 PM
