Results 1 to 20 of 40
Thread: maf screen??
    Member 02sscamaro's Avatar
    long island,n.y
    maf screen??
    i had pulled the screen off now i noticed my gas mileage went down is this normal? 43,000 miles. i don't think it would be my o2 sensers
    The screen is there for a reason.
    The MAF has sensors that meter the air coming in. They are designed to meter the air with the screen in place.
    long island,n.y
    okay but what about the question i asked??
    Arizona
    Well removing the screen will most likely skew the MAF tables a bit. It's calibrated as Mr. Luos said to work with the screen in place.
    It is common practice to remove the screen with alot of the custom tuners but this requires a recalibration of the MAF tables for it to work properly and keep your A/F ratio in check.
    calif.
    Sure it can kill some of your gas mileage--It is more of a stream staightener rather than a screen--It will skew the calibrations of your AFR.More critical on an automatic -- the trans uses a MAF signal to sense load and that info can make the trans shift at improper times.Also the comp picks the wrong timing table becaus of the false info..It affects so many things if not callibrated correctly---Put it back on--The HP gains are so minimal and a stock screened MAF is good for 500 HP---On a M6 the some of the same issues arise but not as severe
    WI
    Blog Entries
    1
    09 EclipseGT 75 Chevy 4x4
    2001 Trans-Am 13 F-XT
    Mine's been descreened for 23k miles without any issues. I do have a manual.
    Member Mjolnir's Avatar
    Feb 2007
    Arizona
    White/Black
    1999 Camaro z28
    +1!
    long island,n.y
    mine is a m6 also
    WI
    Blog Entries
    1
    I didn't notice one bit of difference without it. I don't think it really makes a difference on a stock motor.
    lmpounded SandmanWs7's Avatar
    Dallas, Texas
    2007 CTS-V
    I just put a lid on my car and the screen had pebbles and some trash on it, so it will never be coming off. That stuff in the engine is a big NO NO.
    WI
    Blog Entries
    1
    Quote Originally Posted by sandman22 View Post
    Then something wasn't sealed up right.
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Yes the meter is out of calibration now.
    If you do a search you'll find multiple posts were we discussed this in great detail!!
    If you look at at your LTFT now they will be trying to compensate for your maf.
    This is why we don't do this mod. It takes way too long to reprogram the correct parameteres for the minimal gain.
    Yes the screen is placed there for more than catching objects as others have stated.
    long island,n.y
    okay i want to put the screen back does it just pop in or is there some trick to this???
    Marylandistan
    2001 Trans Am (sold)
    Quote Originally Posted by 02sscamaro View Post
    You took it of didn't you? Reverse process.
    Arizona
    Provided it didn't get boogered up while pulling it out.
    Single Malt rbob93's Avatar
    Ft. Lauderdale, FL
    Sebring Silver
    2000 CamaroSS
    Unless they have changed from 2000 to 2002.....I don't think they can go back in.....Mine broke apart when I removed it
    Went and put a new MAF in when it started throwing codes
    Z two the 8 JonD99's Avatar
    CT
    1999 Chevy Camaro Z28
    when i bought mine it had no screen(3yrs ago), Never once has it thrown a code or anything,
    Arizona
    It probably will never throw a code per say,,,but the extra airflow that is introduced by removing the screen causes the MAF tables to not be accurate. The car will most likely run and drive as it did before.
    Most tuners consider this a free mod,,,and it is,,,but for it to be affective at all, a custom tune is needed. The MAF tables need to be adjusted to compensate. I have talked to a couple of tuners who both recommend removing the screen even on stock motors, BUT,,,this also comes along with a custom tune and MAF tables that have been adjusted accordingly.
    None of them actually recommend just removing the screen and leaving it at that. Larry.
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Quote Originally Posted by JonD99 View Post
    Yes it won't throw codes it just makes your maf unacurate. Like I said if you were to put a scan tool on it you would see the long term fuel trims going crazy now trying to compensate.
    Good description on your post Larry!
    I'm NOT going to go into massive detail cause we have debated this multiple times already........
    I would rather pay a tuner labor time to do other mods than re doing a maf tables to gain 2-4 horsepower!!!
    CT
    I have the predator prog. can that tune compensate, or do i need to goto a shop with ls1edit or efi live?
  1. De-screen MAF? Yes or No...
    By StuntmanMike in forum General Help
    Last Post: 11-24-2007, 10:58 AM
  2. Need new MAF screen, Help!!!
    By FLEX3269 in forum External Engine
    Last Post: 11-13-2007, 07:15 PM
  3. I Need a new MAF screen!, HELP!!
    By FLEX3269 in forum Firebird / WS6
    Last Post: 11-13-2007, 07:04 PM
  4. Keep the screen!
    By weberje in forum General Help
    Last Post: 01-08-2007, 04:37 AM
  5. WTB: Screen for ls1 maf or cheap maf with screen
    By carman in forum Parts Wanted / Trade
    Last Post: 10-12-2005, 09:12 AM
