Thread: sagging wheel
    Member Orange99z28's Avatar
    joliet il
    orange
    99 z28
    sagging wheel
    my passenger rear =wheelwell sits an inch or 2 lower than the others...is this the suspesion? i'm thinking i "popped" a shock, i'm really not sure
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    sagging will be associated with a spring. the shock does not keep the car up.
    joliet il
    orange
    99 z28
    ok, i'll look at it closer in a couple days (hello warm weather). i jacked it up and it still has more force than i have arm strength so i dunno. am i likely to seriously damage anything driving it like this for 2-3 weeks? it drives fine other than losing a little power on the weird angle things are on
    is it feasible to lower my car about an inch for under 350? just replacing springs? and i would need an alignment right?
    orlando, fl
    2014 camaro 2ss/rs
    if you install the springs yourself, then under 350 is feasible. yes, you will need an alignment after you install the springs.
    Jun 2002
    Montreal, CANADA
    triple-black
    2000 CamaroSS convertible
    check the isolator on top of the spring... make sure it's well put on both sides
    Eugenio_SS
    joliet il
    orange
    99 z28
    what exactly is an isolater? just whats between the spring & car?
    i'm extremely impressed with my camaros durability btw. almost hit a deer last night, popped 2 tires going over a pretty big curb and jumped a ditch (like 5-10 ft across 3 or 4 ft down). no damage other than my 1 rim which is a little off balance now (dented rim). just from how it feels goin over bumps and such i figured that kind of abuse would've totalled it. and i want new rims anyway. i'm not sure if i'm really lucky or if i've underestimated the car...
    orlando, fl
    2014 camaro 2ss/rs
    big thick rubber doughnut thingy that goes between the spring and body. keeps all those annoying squeaks, when the spring moves around, from coming into the car.
    Jun 2002
    Montreal, CANADA
    triple-black
    Quote Originally Posted by Orange99z28 View Post
    could that incident be the cause of a the wheels not being same height ?
    joliet il
    orange
    99 z28
    no, the sagging gradually happened(1-2 months). and it survived with the gimp spring, i have a whole new love for my camaro. and its not as bad with the new tires (i put both new on the rear, i popped the 2 right ones)
    i think i'm gonna be doin some springs soon. so hard to decide though, seems everyone has completely different opinions...
  1. July 2012 High Performance Pontiac Wheel Guide - HPP Wheel G
    Last Post: 05-11-2012, 07:50 PM
  2. sagging CAR, help!
    By Hark_Z in forum LT1
    Last Post: 04-30-2011, 11:48 AM
  3. Question: door sagging
    By 02fbody35th in forum Appearance Section
    Last Post: 06-21-2010, 02:34 PM
  4. top sagging
    By yodabill in forum Convertible
    Last Post: 11-21-2006, 06:41 PM
