    Senior Member clg82's Avatar
    Feb 2007
    California
    2000 Trans Am
    Exclamation horse power help......
    Just wanted to see if I could get an approximate horsepower estimate..I have a 2000 ws6 trans am ..i have SLP loud mouth exhaust, slp smmoth bellows, and slp lid with a k&n air filter. And what other inexpensive mods would you suggest? I have read the free ram air mod but is it really worth it??
    Junior Member csess's Avatar
    2001 WS6
    port and polish you maf its free. check out installuniversity.com.
    Porting & polishing the throttle body is a good idea IMO, but messing with the MAF is not a good idea IMO. I would say you are around 315-320 RWHP level. If you could define what is inexpensive to you, that would help us direct you mod wise.
    Painted manta stripe
    Member jag42420's Avatar
    Aug 2006
    Kentucky
    2002 WS6 Trans Am
    Auto or manual? What do you consider inexpensive?
    Polish & port your throttle body http://joshker99.home.comcast.net/tbmod.htm
    Grind your bump stop http://www.installuniversity.com/ins...sity/index.htm
    You can also remove your second baffle in your hood pretty easily. It has a few pop rivets that can be easily drilled out. Sealing your hood to your airbox helps too. You pretty much have to create your own seal, as no one seems to sell the kit anymore. I used some foam, cut it out to match the airbox and seal to the hood, then ran some mechanic's wire through it to wire it to the airbox clamps. Took about 30 minutes, and it changed the sound and pull from the snorkels. Sealing helps keep the air cool and prevents the hotter air from entering, resulting in a tiny bit more power.
    Junior Member josh110781's Avatar
    harrison twp. MI.
    2000 trans am WS6
    can you post some pics of how you have it sealed
    slp lid,maf and smooth bellow. ls6 intake, cnc ported and polished ls6 heads with competition valve job. cam 237,242 .603,.609 113 lsa. pacesetter longtube headers and off road y-pipe. magnaflow catback
    dyno numbers on a mustang dyno
    394 rwhp @ 6300 RPM
    345.7 rwtq @ 4800 RPM
    Aug 2006
    Kentucky
    2002 WS6 Trans Am
    Here's a few quick shots. It's no BGRA, but it works and was free...
    harrison twp. MI.
    2000 trans am WS6
    thanks. so this really helps
    Aug 2006
    Kentucky
    2002 WS6 Trans Am
    They used to sell a kit that was custom molded plastic with weatherstripping to seal the airbox to the hood. It was referred to as BGRA or BG Ram Air http://www.geocities.com/brian98rama..._Air_Pics.html. They quit making them for some reason, and now you can only get replacement parts for it http://www.afterthoughtsauto.com/bg-ram-air.html. The BGRA kit also had plastic inserts to straighten out the cooler air and removed the baffles.
    My setup is not as good as the BGRA, but it is better than stock because it seals the airbox to the hood's nostrils and keeps hot engine compartment air out of the airbox. Several people here have done similar things to seal theirs. Cooler air makes more power. Like I said, you can hear a difference. It feels a bit more responsive, but probably only adds a couple HP.
  1. Z06 Horse Power
    By cam02ss in forum Almost Anything Goes
    Last Post: 02-04-2014, 08:43 AM
  2. Question: How Much Horse Power?
    By TheBigTen-Nano in forum Computer & Tuning
    Last Post: 12-29-2011, 03:35 PM
  3. Question: What's my horse power
    By izzhemp in forum Firebird / WS6
    Last Post: 12-12-2010, 09:41 PM
  4. horse power
    By 2slow4you in forum General Help
    Last Post: 03-02-2010, 06:19 AM
  5. Horse Power??
    By BDowning in forum General Help
    Last Post: 03-19-2007, 03:38 AM
