Results 1 to 10 of 10
04-02-2007, 08:48 PM #1
replacing stock speakers. what ones??
im replacing the door speakers and also the back seat speakers.. i was wondering what the best speakers would be to put in their place. what is the max rms allowed from the stock system. i was looking at speakers that have 35 max rms. is that acceptable?? thanx.
04-02-2007, 11:40 PM #2Member
- Mar 2007
- Chicagoland/Champaign
Red- '97 Z28 M6
Of course that's acceptable....the wont be getting that much though, probably 20-25wRMS - so you are fine. Do you have Monsoon? That may effect what you do with rears depending on if you're gonna add a sub... Do you have an aftermarket HU? Try searching some -- or, even looking at the threads immediately below this one - as this has been discussed quite often recently.
04-02-2007, 11:54 PM #3
i do have the monsoon but i dont have anything else aftermarket.. i want to keep everything stock accept for the speakers.. any recomendations on what would be the best fit?
04-03-2007, 12:13 AM #4Member
- Mar 2007
Red- '97 Z28 M6
Best without running any new wires, modifying any speakers, etc....easiest most simple replacement - Infinity 62.7i's....no question about it IMO.
If not, you can purchase nearly any coaxial speaker and do one of the following on a Camaro:
-modify the speaker to act as 'components' (not easy on all speakers...may not want to cut apart new speakers)
-run wires to it from an aftermarket HU (you don't have one though)
-amp them separately (don't think you are interested in that)
-use just the woofer wires in the doors on your new coaxials (full signal, but less power)
-purchase a component set and mount the tweeter at the location of your choice (may not want the extra work, not completely worth it running it off of Monsoon amp, IMO -- and wouldn't be able to use the crossover supplied running off of the Monsoon amp, but that shouldn't cause any problems anyway, as the crossovers already in existence are probably close enough).
EDIT: crap......all of that was assuming a Camaro - you have several more options with your system, the above hold for the most part -- but a component set would allow you to retain the separate tweeter location, should you wish to do that.
For the sails -- if you want bass still, I would recommend the eu700s -- actually, I have a write-up for them and that's how I found this site -- someone showed me that a writeup already existed, so...I wasted my time I guess. You can see more info at the sticky at the top of this page, or my link: http://www.ls1tech.com/forums/showthread.php?t=639901
04-03-2007, 09:29 PM #5
awesome.. thanx for the info..
04-03-2007, 09:40 PM #6
whats the difference between dual 2 and dual 4?? all i have is the stock monsoon amp and thats the way i would like to keep it.. what would be the more ideal speaker?
04-03-2007, 09:55 PM #7Member
- Mar 2007
Red- '97 Z28 M6
For the eu700s in the sails?
You want the dual 4 ohms, D4. Reason is because Pontiac Monsoon setups have dual 4 ohm subs in the sails, and this acts as a direct replacement.
Camaros have SVC 2 ohm subs, so with D4 subs the VC's are wired in parallel to achieve the 2 ohm impedance the amp likes to "see" -- keep in mind on the Pontiac version though, each voice coil is wired to a separate channel on the amp; so it actually likes to see a 4 ohm impedance in that sense.
If you were asking the difference between dual 2 and dual 4 ohms physically, it would be the impedance of each voice coil (there are 4 terminals unlike typical 2-terminal speakers). So, dual 2 ohm speakers have 2 voicecoils, each with an impedance of 2 ohms, and likewise for dual 4 ohm speakers. Dual 2 ohm speakers can be wired to achieve 2*2 (4 ohms total) or 2/2 (1 ohm) - either double of half (same idea for dual 4 ohms).
....hopefully one of those answers the question you asked
EDIT: VC = Voice Coil if you were unsureLast edited by fredmr85; 04-05-2007 at 01:24 AM.
04-04-2007, 11:45 PM #8
lol.. it is a very confusing topic if you dont know all about it.. but it did help me out.. again.. thanx for the info..
04-05-2007, 03:53 AM #9Rock-n-Roller
- Jul 2005
- OHIO Go Buckeyes!
Arctic White- '07 Trailblazer LT
You might want to consider making your own speaker baffles to replace the plastic ones. Go to Page 4 of my Sound Domain site to read why.
04-09-2007, 02:54 AM #10
By ls1ws6ben in forum Stereo and ElectronicsReplies: 23Last Post: 02-28-2011, 01:09 AM -
replacing speakers..
By Ws6islife in forum Stereo and ElectronicsReplies: 4Last Post: 11-02-2009, 08:52 PM -
replacing speakers
By 02blackbirdws6 in forum Stereo and ElectronicsReplies: 8Last Post: 09-14-2009, 09:17 PM -
Need some advice on replacing my stock speakers!
By JSGTPD in forum Stereo and ElectronicsReplies: 11Last Post: 08-15-2006, 05:11 PM
