Results 1 to 20 of 20
    Ocala, FL
    1998 Formula
    1998 Ram Air Formula
    I'm selling my car. It's a 1998 Silver Formula.
    Mods
    Performance
    233/235 .644/.594 112+2LSA Cam
    Ported heads (good job done by prev. owner)
    PRC gold dual springs (rated to .650 lift)
    LS6 intake (painted silver to match car)
    titanium retainers
    TSP hardened 7.425" pushrods
    new valve locks and spring seats
    COMP lifters (10k miles)
    NGK TR55 spark plugs
    MSD wires
    ASP Underdrive Pulley
    Suncoast creations airbox w/ K&N filter
    Z06 clutch w/ Pro 5.0 shifter (20k miles)
    Hurst line lock
    Cross drilled and slotted rotors
    Hawk HPS pads
    4:10 gears (30k miles)
    !EGR & AIR
    TSP ported oil pump
    rollmaster double chain
    walbro 255lph pump w/new fuel filter (10k miles)
    Tuned spot on by Jeremy Formato
    Drivetrain
    Built tranny (20k miles)
    Built rear-end with eaton posi and alum. cover (30k miles)
    Poly motor mounts and trans mount.
    Exhaust
    Hooker LT's ceramic coated
    TSP x-crossover
    18" Sweet Thunder's stainless
    turndowns at the rear end
    Suspension
    Eibach ProKit lowering springs
    BMR adj. torque arm
    Spohn adj. panhard rod
    BMR lca's w/relocation brackets
    BMR weld-in subframe connectors
    Also just installed new tie rods and had it aligned
    Wheels/Tires
    AFS chrome ZR-1 replicas
    17x9.5 +38mm offset
    17x11 +36.5mm offset
    Sumitumo HTRZ's 275/40ZR-17 80% tread
    Sumitumo HTRZ's 315/35ZR-17 80% tread
    Random
    Pioneer CD deck
    Infiniti Kappa component speakers
    5% tint on side and rear windows
    SLP leather shift knob
    polished taillight centerpiece (no firebird logo, just shiny black)
    Suncoast Creations hood
    Stock stuff
    graphite leather
    t-tops
    power windows
    remote keyless entry
    remote hatch opener (that actually works, lol)
    door handles and side mirrors are body colored
    Problems
    Small crack in dash
    Small chip in windshield (not very noticable)
    Two rock chips on hood
    Front left side panel has a chip in it
    radio does not work because it does not have an antenna, however the cd player works just fine.
    The clear started to peel some on the front clip. As you can see from the pics it's not very noticable.
    I have reciepts for a decent amount of the parts including the transmission rebuild if you would like them as well as a couple old dyno graphs with previous cams I tried out.
    Has 120,000 miles on it with a fresh oil change (done every 3000)
    Car has excellent oil pressure and runs very well. It was dyno'd with a 224/224 .565/.565 cam and made 390rwhp 385rwtq. With the new much larger cam it has to be over 400rwhp. I had the car tuned but off the dyno. It is spot on and took a few hours to get it there from one of the best tuners in Florida. I took the car to the track one time and ran a 12.3 @ 119 (really soft launch and soft shift into second to be gentle on the rear, hint the high mph for the et)
    Most of the mods are within the 20k mile range. I've changed all the fluids 20k miles ago and oil every 3k miles or less. Changed oil at every cam swap (3). All mods are in great shape as far as I know. I put new valve seals and cleaned the heads and new lifters when I put the last cam in. So really the only thing that has the full 120k miles on it are the bearings and rings, unless they were replaced by previous owner. I know the cam bearings looked great when I swapped cams. I also know that there was still a good cross hatch in the cylinders when I replaced lifters. The car does not smoke so the engine is in good shape.
    $11,750
    Willing to trade for an 03 cobra, depending on price.
    I have a few more pics, but they aren't very good. I have fixed a few things since they were taken. I'll point them out.
    Exhaust and Suspension shot (old, not good quality)
    Engine bay (filter looks dirty, but is now cleaned) Also no longer has the STB
    Interior shot (seat belt holder is broken - fixed now. Clutch pedal is missing rubber - fixed now.)
    Ocala, FL
    1998 Formula
    To the top.
    Ocala, FL
    1998 Formula
    To the top.
    Member 70hemicuda's Avatar
    Feb 2007
    exactly the car i want...just one year too early. i love formulas. bump for ya
    Ocala, FL
    1998 Formula
    One year doesn't make that big of a difference. Besides I already fixed all the issues such as the oil pump. But anyhow you're in Texas and I don't want to drive more than 200 miles.
    Ocala, FL
    1998 Formula
    To the top.
    Feb 2007
    i cant believe nobody wants the formy...wanna keep it a year?
    Ocala, FL
    1998 Formula
    Not really, getting married in August. I have someone that's supposed to call me this week. So we will see.
    Ocala, FL
    1998 Formula
    To the top.
    Member screamin chicken's Avatar
    sc
    Black, Red, Silver Jade
    00 WS6,95 Ta, 69 R code
    I wish I could get it to add to my collection good luck heres a TTT
    2007 Yukon XL (sold)
    2014 Z71 LTZ 3LZ (sold)
    2010 Escalade Platinum AWD , 6.2
    2017 Silverado HC , 4x4, 6.2
    2000 WS6 ASC#2300 Holly LS6 intake, TR Custom grind cam, Mac Mids w/ ORY,Hotchkis LCA's, PHB, BMR Extreme STB, BMR re-location brackets,Eibach Sportlines, GMMG, Mccleod Pro 5.0, SLP SFC's, OEM ZO6 wheels
    1995 TA
    1969 R code Mach I my new project
    Ocala, FL
    1998 Formula
    To the top.
    Ocala, FL
    1998 Formula
    To the top.
    Ocala, FL
    1998 Formula
    To the top.
    Oklahoma
    looking
    98 or newer
    be intersted in a trade for a 347 storked and blown 93 blk Cobra? I have it listed here on pg.2
    Ocala, FL
    1998 Formula
    No thanks.
    Ocala, FL
    1998 Formula
    Price down to 10,700.
    Ocala, FL
    1998 Formula
    To the top.
    Ocala, FL
    1998 Formula
    To the top.
    Ocala, FL
    1998 Formula
    To the top.
    Ocala, FL
    1998 Formula
    To the top.
  1. for sale 1998 sgm formula
    By rshooch in forum Vehicles For Sale / Trade
    Last Post: 01-06-2008, 05:53 PM
  2. 1998 Formula WS6
    By Mike24 in forum Vehicles For Sale / Trade
    Last Post: 09-09-2007, 11:33 PM
  3. 1998 Formula
    By 980birds in forum Vehicles For Sale / Trade
    Last Post: 11-03-2006, 04:23 PM
  4. FS: 1998 Formula WS6
    By TexasLT4 in forum Vehicles For Sale / Trade
    Last Post: 05-11-2006, 12:55 PM
