Results 1 to 16 of 16
04-01-2007, 11:28 PM #1
Where to connect remote wire on amp???
Right now, I've got 2 10's with an audiobahn amp. The remote wire is just connected to a switch by the tcs. I'm tired of having to flip the switch off and on all the time, and also, if I forget to turn it off, it'll eat my battery. How can I hook up the remote wire to turn on and off with the radio (or even just when I turn my car on and off)??? I was hoping for something pretty simple since I'll be doing it myself. Any help would be really appreciated. Thanks.
04-01-2007, 11:40 PM #2Member
- Mar 2007
- Chicagoland/Champaign
Red- '97 Z28 M6
If you have an aftermarket HU, there should be a remote turn on from the harness (usually blue).
If you have the factory HU, look for the power antenna wire (pink), and use that -- it will turn on and off with the HU.
04-05-2007, 04:56 AM #3down with the lot lizards
- Dec 2006
- Pensacola
Red- 2001 Camaro SS A4
And if you dont have that (which you more than likely will), run it to the NEGATIVE side of the Accessory fuse in your fusebox.
To do this, pull out the ACC fuse, then take a mulitmeter and ground it out to the chassis somewhere, then touch the positive test lead to each side of where the fuse went(where the fuse poles went) and turn the car on to see if there is voltage, if you find the side where there is NOT voltage, then your in good shape, What I did was wrap the wire around the fuse pole that plugs into the negative side...hadn't had a problem since
04-05-2007, 12:37 PM #4
04-05-2007, 12:59 PM #5Member
- Mar 2007
Red- '97 Z28 M6
I would refer to my post first; then follow his instructions. The only reason you would need to do that is if you have a really cheap aftermark HU without remote turn on signals. Let us know what HU model (if aftermarket) you have, if you have the stock Delco/Monsoon HU -- then you are automatically fine.
04-05-2007, 01:21 PM #6Senior Member
- Nov 2006
- Indianapolis
I put my signal wire for my amp for my 2 10" subs on the 1 amp fuse for the RAP fuse. You can get a thing that slips on the back of the fuse spade as you install the fuse and it gives you a terminal to attach the female spade terminal to. That way whenever I have RAP then my amp is powered also. Any auto parts place should have this.
04-05-2007, 02:03 PM #7Member
- Mar 2007
Red- '97 Z28 M6
04-05-2007, 04:32 PM #8
04-05-2007, 11:30 PM #9
I've still got the factory head unit in, so I'll check it out when I get the chance. I appreciate your help. Thanks.
04-06-2007, 02:55 AM #10Senior Member
- Nov 2006
- Indianapolis
So, do you need to remove the factory HU to access the pink wire? Or do you get the pink wire back near the antenna? I ran my remote wire along my B+ until they separated near the fuse box. Maybe I could've accessed the remote at the antenna on the right quarter panel area!
09-03-2012, 01:08 PM #11
Anyone know if Camaros have the antenna wire already run in the back near the amp?
09-04-2012, 02:24 AM #12Senior Member
- Nov 2006
- Indianapolis
IDK for sure. Possible tho, since the cars are twins. It would make sense from a wiring perspective for GM.
09-04-2012, 10:07 AM #13
I didn't see it back there... I'll run a wire from the radio if I need to to get this turn-on signal.
How do you guys usually turn your aftermarket amps on?
09-04-2012, 02:12 PM #14Senior Member
- Nov 2006
- Indianapolis
I hooked up mine as explained above. Using a DVOM or test light, find a fuse that only has power on accessory and ignition on. Not a fuse that has power at all times.
09-06-2012, 05:17 PM #15
Remote wire on the back of the HU. You want it to only come on with switched power or you will come out to a dead battery. You also want to make sure it's putting out enough voltage to actually run the amp. The switched wire is typically blue. I suggest a wire tap or solder. Do not use the switched power to the amp located in the rear of the car. That does not have enough voltage to run and amp. The moment you put a decent amount of power to it, it will shut the amp down. Don't make the same mistake I did.
09-06-2012, 05:21 PM #16
The switched power is typically the yellow wire on aftermarket HU's. Don't use the orange, your turn signals will stay on.
Can not connect to VCM
By blackcar in forum Computer & TuningReplies: 18Last Post: 09-26-2012, 05:55 AM -
big 3 ? where to connect to Alt.
By qwik219d9 in forum Stereo and ElectronicsReplies: 0Last Post: 10-21-2009, 09:04 PM -
remote wire color (stock amp)
By MnLS1 in forum Stereo and ElectronicsReplies: 3Last Post: 03-03-2008, 11:16 AM -
Not beging able to connect.
By 95Fyrebyrd in forum Computers / GamingReplies: 11Last Post: 02-28-2008, 08:34 PM -
How would i hook up a second amp to the battery and the "remote wire"?
By Mike Hawk in forum Stereo and ElectronicsReplies: 6Last Post: 09-15-2005, 05:04 PM
