Results 1 to 16 of 16
    Member Hodgesz28's Avatar
    Maryland
    5 (100%)
    SOM
    2002 SOM Z28
    1999 Arctic White Trans Am Street/Race Car
    I have a 1999 Arctic White Trans Am with 63xxx on the body. The car is in mint condition with minimal little knicks from rocks on the front bumper. When I bought this car it has a bra on the front of it which I thought was hideous! I took it off and you may be able to see a slight fade in the paint. It's really not that noticeable but I did want to make it known to the buyer. Now let me get started with all the goodies!
    Appearance:
    WS9 Outlaw Hood w/heat extractors "fully functional" all fiber glass, very very light weight!
    Side moldings removed
    Wheels and Brakes:
    Brand new tires all the way around
    Stock 5 star chrome rims, no blemishes
    Hawk brake pads
    Slotted rotors
    Drivetrain:
    CPT Pro Race 4L65E, 0 miles on it since refreshing "I currently hold CPT record for fastest car that has one of his 4L65E's in it" 9.7 @ 146mph. Has warranty on it!
    TCI 3800 blower, NOS converter w/lockup
    Stock 10 bolt w/3.73 gears, and a TA Cover this 10 bolt has been 10.4's in the 1/4. No whining at all!
    Exhaust:
    Hooker LT's, A.I.R Welded closed.....no emissions
    Custom Y-pipe
    3 inch cutout
    B&B Tri-flow cat-back
    Engine:
    Jackson Motorsport Forged 347 shortblock
    Diamond Forged 10.5-1 pistons
    Eagle Rods
    Comp Cam 234 236 on a 112 LSA
    5.3 liter fully ported and polished heads
    Comp 918 Beehive springs
    Comp Hardened stock length push rods
    Yella Terra 1.7 Rockers
    LS6 Intake
    Ported and Polished stock TB
    Smooth Bellow
    K&N FIPK "works amazing since the hood is fully functional!"
    Power Adder:
    I have a 100% complete fully functional NOS direct port kit that is plumbed into the LS6 intake. I have jets from 175-400. The jets that are currently in it are the 250. It has a complete stand alone fuel system so you don't have to worry about starving the motor when you spray. External fuel pump, holly fuel pressure regulator, purge, MSD window switch, and a Jimmy Jams WOT switch and ashtray switch panel. Everything is wired up and works perfectly. Last season I had a blower on the car and it went a best of 9.7 @ 146. And that was with just about everything listed minus the 10 bolt. I did have a Ford 9 inch w/4.11 gears. I have since pulled the blower off and put in a new forged 347 block and built if for NOS. The car will easily go 10's as it sits and should go 9's with some weight reduction and maybe some more juice. But this is a for sure 10 second car now. I have slips from last year and 2 vid's of the car going 10.0 and a 9.98. I am getting the dyno tuned for the MOTOR only. The buyer can get it tuned for the NOS as I do not want to get it all set up for the 250 shot if the buyer doesn't want to run that shot. So I will leave that up to the buyer. There is absolutely nothing wrong with this car at all. It sounds very aggressive with the cam and performs just the same. If you have any questions please PM me.
    I am not going to dick anyone around and I don't expect any low ballers. I know what I have in this car and for those who know what is cost for all these parts you know this is not a cheap build. The tranny does have a warranty and if you have any questions you can ask me or call Frank Cahall of CPT. There was absolutely nothing wrong with the trans when I took it to Frank after last season I just simply wanted to make sure everything was ok before I sold the car! I am asking $16,500 OBO. If you feel that is not a reasonable price then please PM me and we can talk. I am NOT looking for trades and PLEASE DO NOT LITTER MY THREAD UP WITH WHY YOU THINK THE PRICE IS NOT TO YOUR STANDARDS OR IF YOU HAD THE MONEY YOU WOULD GET THIS!!!!
    I will post pics within the next few days as I am being held up in bed due to surgury on Friday. I am just posting this up now without pix to get the word out and to see if anyone is interested! Thanks
    Maryland
    5 (100%)
    SOM
    2002 SOM Z28
    Forgot to mention this car has never been sprayed since the new build! And the car has a brand new ASP underdrive pulley, and upgraded 30lb injectors.
    1998 trans am
    hello, do you have a cell number where you can be reached at, id like to be able to talk to you as soon as you are able. Also if you can send pics to
    [email protected] Thanks
    Maryland
    5 (100%)
    SOM
    2002 SOM Z28
    Quote Originally Posted by 99duesway View Post
    301-788-8447, call me tomorrow after 9am....my voice is kinda weak because I just had surgury but I can talk to you. If I don't pick up leave me a vm with a # that I can reach you back at. I am trying to get pictures within the next 2-3 days! Hope to hear from you soon!
    1998 trans am
    hello, tried to call you a couple times this week, but always got a weird answering system that said all lines are busy at the time, are you sure this is the correct number? My cell number is 419-305-9058 ask for Andy. Call me anytime tomorrow after 11 am. Thanks
    Maryland
    5 (100%)
    SOM
    2002 SOM Z28
    Ok guys here are most of the pictures I will get some more interior pix hopefully tomorrow the day was comoing to an end. If you have any questions at all please email me @ [email protected] or call me @ 301-788-8447. I DO HAVE A WEIRD ANSWERING MACHINE JUST LISTEN FOR THE BEEP!!!! LOL. anyways I am not mounting the NOS bottle I will leave that for the next buyer cause I am not going to mount it some place you might not want it, so thats on you. Everything is 100% covered up you cannot see any wires, lines, brackets or anything if someone looks under, or in the car! On the switch panel I used the purge button and the blue button turns everything on "stand alone, arms purge, and arms NOS" the other 2 buttons you can wire up anything else you want to!
    Maryland
    5 (100%)
    SOM
    2002 SOM Z28
    Here are more since it would only let me post 15 at a time.
    Maryland
    5 (100%)
    SOM
    2002 SOM Z28
    And I just bought and put a brand new battery in today!!!!! Come with an 84mth warranty to any Advanced Auto parts store!
    Maryland
    5 (100%)
    SOM
    2002 SOM Z28
    Shit I also forgot to mention the sale will also include a set of 2001 chrome Z28 wheels that have a set of almost brand new MT ET Streets! Only the 2 wheels have tires the other 2 is just the rims! This is what the rims and the tires look like!
    Maryland
    5 (100%)
    SOM
    2002 SOM Z28
    Hm thats odd when I first listed this without pix a ton of people were interested now no one is now that I have pictures???
    Maryland
    5 (100%)
    SOM
    2002 SOM Z28
    The car will go up on EBAY next week if it is not sold!!!! This is one hell of a deal!!!
    1998 trans am
    waitin on dyno numbers
    Maryland
    5 (100%)
    SOM
    2002 SOM Z28
    Should have them by either tomorrow or the day after
    Maryland
    5 (100%)
    SOM
    2002 SOM Z28
    Just installed a brand new Fuddle Racing converter.....I didn't like how the TCI performed on the dyno........it is brand new paid 500.00 for it!!! Will have some #'ers in a few days!! But it put down 421RWHP N/A.
    Maryland
    5 (100%)
    SOM
    2002 SOM Z28
    $15,500.......???
    Maryland
    5 (100%)
    SOM
    2002 SOM Z28
    TTT for tuesday
  1. white 1999 trans am
    By transamgirl17 in forum Member's Rides
    Last Post: 06-17-2011, 05:45 PM
  2. For Sale: 2000 Trans Am WS6 6 Speed Arctic White Modded, $10,500
    By JerseyLS1 in forum Vehicles For Sale / Trade
    Last Post: 05-15-2011, 12:00 PM
  3. WTB 2002 Trans Am M6 T-tops ARCTIC WHITE
    By Gohard in forum Vehicles For Sale / Trade
    Last Post: 05-30-2010, 07:47 AM
  4. 2001 Trans Am WS6 For Sale Arctic White
    By NiteRiderWs6 in forum Vehicles For Sale / Trade
    Last Post: 07-27-2009, 03:12 PM
  5. Arctic white trans am 1998 super clean in socal.........
    By getheadallthetime in forum Vehicles For Sale / Trade
    Last Post: 08-14-2006, 03:57 PM
