Thread: Dome and Map Lights Problem
03-29-2007, 05:34 PM #1Member
- Oct 2005
- Keyser, WV
DNBPM- 2000 UltraZ
My dome and map lights will not go off when the car is running.
I recently replaced my interior bulbs with Blue LEDs and installed a pod with gauges. No matter how long I leave the car run the lights stay on and no the switch is not on. Any help would be greatly appreciated. [email protected]
Thanks,
John Junkins
03-29-2007, 07:51 PM #2
Have you checked the hatch switch although I would think that would make the interior lights come on whether the car was running or not.
Is this a new problem since the LED and gauge install? If it is how did you wire the gauges in? Might have something to do with it.
03-29-2007, 09:52 PM #3
whenever you hooked up the lights for the gauges you might have hooked up the wrong ground or power to the wire that contoles the interior lights...if you hooked it up to the ignition switch power of anything that has full power when its running like the stereo you will get this problem...but go back and trace your wires and see what you come up with .... keep us posted tho
04-01-2007, 03:44 PM #4Member
- Oct 2005
- Keyser, WV
DNBPM- 2000 UltraZ
YES it is new since Installing the LED and guages. I also unhooked the power and wire going to switch and they still stay on? I'm going to try removing and installing the orginial bulbs in the map and dome. Any help would be greatly appreciated. [email protected]
Thanks Again,
John Junkins
dome lights
By barryz in forum Stereo and ElectronicsReplies: 8Last Post: 01-19-2010, 05:53 AM -
Converting Stock Dome Lights to LED
By GULLETT17 in forum Stereo and ElectronicsReplies: 13Last Post: 01-13-2009, 11:16 AM -
Interior lights (dome and map) out
By tom96formula in forum Cadillac CTS-VReplies: 7Last Post: 06-29-2008, 11:59 AM -
dome lights at night time turning on WTH
By mattycakes98TA in forum General HelpReplies: 5Last Post: 08-19-2006, 06:30 PM -
dome lights
By malibumaniac in forum Stereo and ElectronicsReplies: 10Last Post: 09-13-2005, 07:37 PM
