    American Muscle
    Jun 2006
    Randolph NJ
    Blue
    2001 Formula
    predator handheld
    I was wondering if the diablo predator tuner is worth it for a 6 speed car. I have heard good things about it on the a4's but i wanted to know what i could expect as far as hp and performance on a 6 speed. The main reason i am looking into the handhelds is because i am putting 4.10's in soon and i will need to correct my speedo. I would just hate the spend the money right now if i won't see any gains from it.
    01 Formula M6 Dark BLue Metallic
    Mods:SLP Lm Catback,Pacesetter Lt's with off road Y pipe, Complete Slp cold air kit,Free mods, B&M ripper shifter,cartek dyno tune,Umi Lca's and panhard rod,Ls7 Clutch Kit,4.10's,mickeyT Dr's,and TT2's
    12.51 1/4 @113 340rwhp 352rwtq
    General Mota's! stevegrizzle's Avatar
    Around Tampa , FL
    mid blue
    99 m6 z28
    not worth it, buy some drag radials and headers
    Member speedkills's Avatar
    Aug 2006
    Arlington, TX
    1999 Chev Z28 Camaro,
    If that is all you want, to correct the speedometer it is not worth the hundreds of dollars. Find someone who has a hand held and get them to change it for you.
    Arkansas
    99 Trans Am
    someone with a handheld would not be able to do it for him since they are vin locked to only car only unless the original car is returned completely back to stock. you will have to find a tuner to have the speedo corrected but they should not charge you to much just for a speedo correction, i think 50 bucks is about normal for that.
    as for other gains you would be able to get some live data feedback and DTC readings. Umm the only thing that would really benefit you performance wise would be if you were runnign nitrous then you could retard your ignition timing a bit. also you would be able to richen or lean your fuel mixture 5% in either direction at WOT which could do you some good in the 1/4 but without a wideband 02 it would take alot of track tuning and some very consistant runs in order to know what is best for your car.
    All in all it would help you out a bit, but not really worth the money unless you can find a good deal on a used one.
    Raleigh, NC
    sebring silver
    02 Camaro SS
    I may not be in the right section,however I'll throw this out. I'm adding lt headers withthe y pipe. Any suggestions/applications of the oxygen sensors, i.e. front, back, one, two? Any help would help. rw
  1. For Sale: DIABLO SPORT PREDATOR Handheld Tuner/scanner
    By Dr.Crash in forum Parts For Sale / Trade
    Last Post: 03-29-2009, 08:48 AM
  2. Sct Handheld
    By OnEbAdReDSS in forum Computer & Tuning
    Last Post: 04-11-2008, 10:16 AM
  3. WTB VHP Handheld for 99
    By Wheeler99WS6 in forum Parts Wanted / Trade
    Last Post: 04-14-2007, 04:18 PM
  4. vinci handheld
    By white98 in forum Southern Members
    Last Post: 05-28-2006, 08:23 AM
  5. Handheld Disaster
    By R&L'scamaro in forum Computer & Tuning
    Last Post: 03-02-2006, 04:22 AM
