Results 1 to 10 of 10
    Junior Member Hoss93's Avatar
    Blk
    2002 Camaro z28
    Am I gettin screwed?
    '02 Z, M6. Transmission overhaul, new stock clutch and flywheel - charging me $3,019! Am I gettin it up the arse? I'm in Texas....
    SS#430 1 of 74 7camaro7's Avatar
    Nashville, TN
    02SS6spd VERT!
    Sounds like you're getting a new one ripped to me! DAMN!
    Senior Member JonB's Avatar
    Florida
    2005 GTO
    Since a brand new tranny is only about $3600 plus a clutch which is about $400 for a totall of $4000 and they want $3k for just a rebuild. Id say yeah your getting screwed.
    doylestown, Pa
    SILVER
    2004 CTS-V
    What makes you think you need a new flywheel. You don't just replace it when you need a new clutch.
    no more 4th gen secondgearscratch's Avatar
    Jun 2006
    St. Louis, Missouri
    2000 z28
    yeah i agree. it wont be that fucked up i wouldnt think. and you can get them resurfaced for way less than a replacement. and they want 3 grand for a rebuild with oem components. get your car to another shop. asap.
    they better be putting in a spec clutch set up or something for 3 grand. thats insane!!!
    Winter Garden, FL
    1999 Camaro Z28
    Yeah unless your flywheel is chattering I would tell them to resurface them.
    LS1 land
    and i wouldn't put in a new stock clutch. Get an upgrade from stock like the LS7. Whats wrong with the trans anyway??
    Ontario Canada
    2001 Camaro ss
    ..for that kind of money..check e-bay, there are shops that specialize in ls1 stuff...you could pick up a tranny for about 5 to 6 hundred...that will leave you with funds for other improvments...r and r a tranny.....maybe 4 hours in a qualified shop...that's a guess but should be in the ball park...good luck
    Blk
    2002 Camaro z28
    Thanks all. Ya I thought that was outrageous. My synchro in 5th has been giving me probs for awhile. But the clutch hasn't been slipping at all. The throwout bearing was making a little noise but chirps 1st thru 4th.
    When in 5th, the gear shift would move to and fro depending on throttle. Felt like it was about to pop out of gear. Took a long trip the other day and it got pretty hot. Stuck in 5th gear when I downshifted and lots of shearing sounds trying to get it out. Then once I made it home it just got worse and wouldn't even go into any gear. They told me the flywheel was in really bad shape and would show it to me even though I told them just to resurface it.
    I got a quote from two shops - $1,700 for a tranny. They told me $300 to put it in. A clutch I can get for like $350 and have the flywheel resurfaced. They are charging me $380 for labor whether I use them or not. DANG!
    LS1 land
    i would check out "T56 rebuilds" they have good prices. Just google the name i dont think i can link a non sponsor.
  1. allways gettin screwed over
    By GhostTransws6AM in forum Almost Anything Goes
    Last Post: 09-23-2009, 08:49 PM
  2. My babys gettin..
    By Kaotic_ws6 in forum Firebird / WS6
    Last Post: 02-10-2009, 06:20 PM
  3. gettin my cts v tomarrow!!!
    By JOHN_DEERE_LS6 in forum Domestics and Foreigns
    Last Post: 06-22-2008, 11:20 PM
  4. soo im gettin screwed
    By blackhawk01 in forum Almost Anything Goes
    Last Post: 02-05-2008, 09:14 AM
  5. gettin busted
    By astyles in forum Almost Anything Goes
    Last Post: 12-05-2006, 10:48 AM
