Results 1 to 10 of 10
    d
    2002 z28
    stall question.. LOCK UP or no lock up whats the difference?
    whats the diff. have a 02 stock z soon w NX and is bascailly a daily driver if that helps.
    Senior Member Zboner's Avatar
    cincinnati/northern ky
    99 SS
    get lock up unless you want to kill your gas mileage
    a non-lockup convertor will also build more heat. Lock up is definitely the way to go.
    Pontiac Addict 01RaptorTA's Avatar
    Northern Indiana
    Black on black
    2003 Bonneville SSEi S/C
    Ok, im sorry, but i have to play the idiot here...what is a lock up?
    Arkansas
    99 Trans Am
    Quote Originally Posted by 01RaptorTA View Post
    there is a lock up clutch in your trans that will lock your stall convertor instead of letting it slip to its stall rating. I dont know if i described that very well but thats the best I can do lol
    Junior Member ken harris's Avatar
    FLORDIA
    1999 transam
    get the lock-up
    Aug 2006
    29 palms
    2000 pontiac TA vert
    I have driven both and I can definitly say if your gonna drive on the street get the lock up converter
    Mrs.'s Boobies
    North Hollywood, Ca
    Onyx Black
    Quote Originally Posted by juiced99ws6 View Post
    Good try, but not exactly.
    A torque converter has a clutch like (albeit smaller then) a manual. It is located at the front cover, towards the engine of the converter. Upon meeting certain calibration parameters from the ECM (for electronically controlled trans), the transmission is signaled to apply fluid through the input shaft to the torque converter clutch (TCC). This hydraulically/pmechanically locks the engine and trans input shaft together. This dramatically reduces heat and allows the engine to have a lower rpms for any given MPH, resulting in better fuel economy. Unles you are strictly drag racing, you are best suited to go with a lock-up style converter. Most aftermarket companies that mak converters for the LSx market will only build a nonlock-up unit on a custom order. Off the shelf models will have the TCC.
    George P. Lara
    Mine 2001 Camaro SS #0391: FQuick Garage
    Mrs.'s 2002 Camaro SS #7072: FQuick Garage
    d
    2002 z28
    thanks for the deep details, finally understand fully
    Northern Indiana
    Black on black
    Quote Originally Posted by 12secSS View Post
    Thanks for that little explaination, definitely helped.
  1. VATS bypass/ignition cylinder lock question
    By mezzoni in forum General Help
    Last Post: 03-25-2013, 06:43 PM
  2. SLP Line Lock Question
    By SMWS6TA in forum General Help
    Last Post: 12-31-2011, 08:57 AM
  3. difference between ign lock cyl and tumbler?
    By flyinlo28 in forum General Help
    Last Post: 07-29-2010, 06:20 PM
  4. tranny,lock up/no lock up.................
    By NEXSTAR7 in forum Automatic Transmission
    Last Post: 10-07-2009, 12:17 PM
  5. question about door lock knobs
    By enthashyt in forum General Help
    Last Post: 12-05-2006, 12:40 PM
