    Member sfletch2000's Avatar
    Feb 2007
    Bakersfield, CA
    86 Buick Grand National
    02 WS6-M6 407 RWHP
    Header Installation
    I'm gonna attempt to install the set of pace setters and y pipe i just picked up and was wondering what all needs to be taken off to put them on. Plus any tricks to make the intall as easy as possible would be appreciated
    Pull the starter, coil packs, oil filter, oil dipstick, and you want to change you plugs and possibly wires while you are doing it.
    Painted manta stripe
    Lubricant
    Guest
    Agreed.. And I second the plug change... Since this is the 1 time they will be easily accessible!
    Feb 2007
    Bakersfield, CA
    02 WS6-M6 407 RWHP
    ok well what plugs do i go with
    SS#430 1 of 74 7camaro7's Avatar
    Nashville, TN
    02SS6spd VERT!
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    here's pics of when i did my swap
    http://www.stealthram.com/dynatech.htm
    d
    2002 z28
    nice install pics
  1. Hooker Header installation on LS1
    By 64MonGooSe64 in forum External Engine
    Last Post: 01-05-2009, 03:36 PM
  2. header installation?
    By silverbullit1972 in forum External Engine
    Last Post: 08-11-2007, 01:39 PM
  3. Header Installation Write up?
    By NiteRiderWs6 in forum External Engine
    Last Post: 06-12-2007, 02:18 PM
  4. Header installation
    By silver35thss in forum External Engine
    Last Post: 04-09-2007, 06:29 PM
  5. QTP header installation
    By 01firehawk915 in forum External Engine
    Last Post: 04-04-2007, 07:01 AM
