    Member 02sscamaro's Avatar
    long island,n.y
    camshaft install??
    i had gotten a price of $3,000 4 camshaft, pushrods, springs, retainers, and tune and of course install. is this right???
    Aug 2006
    Missouri
    94 Camaro Z28
    Quote Originally Posted by 02sscamaro View Post
    I hope they install an expresso machine in your car for that price too. Damn, for parts and labor, that is WAY TOO much I think. So, parts, cam swap, and new valvetrain I think shouldn't be over $1.7K. Parts shouldn't be more than $1000, then install...well, just for a header install, I was quoted $500, so maybe a $1000 or so install...I don't know. All I know is $3K is too much. Maybe $2K is more reasonable, but I wouldn't pay 3 unless it was for a new fully built enigne.
    Member SSpdDmon's Avatar
    Farmington, MI
    SOM
    '01 Camaro SS
    I think I've heard of people getting it done for $1200 for the actual install/tune plus parts. It really depends on the labor rate the shop uses and how many hours they allocate for the job. Someone who works on LS1's regularly should be able to do a cam swap in ~6 hours or less. They can drop the k-member with the car on the lift in a couple hours, do the swap in a couple hours, and bolt it back up in a couple hours. Assuming they charge an $80/hour rate, the labor part of the swap should be $480. Build in a little cushion, plus your time on the dyno & tuning....$1200 sounds very fair to me. If you're going to do that, you should have them throw some poly motor mounts on as well. Nothing worse than a y-pipe banging the floor after an install.
    chicago
    98 trans am
    Paid 1400 for everything you mentioned including the labor and dyno tune. It was a cam special offered by a sponser a while ago. Just wait for a sponser to post up a special. Was this by a local speed shop or a ls1 shop?
    ORNGP33L 1BADDLS1's Avatar
    Long Island, NY
    Hugger Orange
    1999 Camaro Z-28
    where in NY are you located??? there are plenty of shops that specalize in LS1's...
    long island,n.y
    i'm in smithtown roller rockers were also included i forgot to mention. and please don't say vette doctors i wouldn't let them work on my lawn mower.
    Long Island, NY
    Hugger Orange
    1999 Camaro Z-28
    vette doctors blow....
    unless you have a vette... then they massage yo shiiiiitttttt
    i have a few shops in mind fellow LI-er
    what camshaft you have in mind???
    save the $ and keep the stock rockers
  1. Used camshaft
    By reedld in forum Parts Wanted / Trade
    Last Post: 12-28-2012, 12:23 PM
  2. Camshaft Bearings Install - Bearing The Load
    Last Post: 07-17-2011, 04:31 PM
