Results 1 to 20 of 23
03-18-2007, 02:03 PM #1
Will removing my AIR system cause any damage?
I have a 2000 Z28 and was wondering if I removed my AIR pump and hoses; would it do any damage and/or lead to premature cat failure and/or throw any codes? I don't plan on doing any LT's or removing the cats anytime soon.
03-18-2007, 02:21 PM #2Senior Member
- Jul 2005
- Jacksonville, FL
Don't know for sure about premature cat failure but it will throw a SES unless they're turned off - extended 120K warranty on the cats will be out the window too. Still have mine, keeping it until I do LTs.
03-18-2007, 03:24 PM #3
03-18-2007, 03:37 PM #4
It shouldn't do any mechanical damage to the car, it will just set the SES light because the A.I.R. system won't be functioning.
The AIR system is designed to help light off the cats quicker when the engine is first started. So in the first few minutes of a cold startup, the AIR will pump fresh oxygen into the exhaust stream to help the cats start functioning more quickly and reduce emmissions.
Removing the system really provided no benefit short of reducing the cluttered mess in the engine bay.
03-18-2007, 04:49 PM #5
Yes it will probably throw a code. No it won't cause EARLY failure. But if you have other issues such as a rich condition that is letting raw fuel get to the cats without the air pump helping cool them down then yes it will aid in earlier failure.
03-19-2007, 10:44 AM #6
Mine has been just fine. Had it turned off before I got LTs and had no problems. It reduces clutter some, maybe drops a lb? I think the main thing that is worth doing is plugging up the hole in the airbox that the AIR tube would be stealing from, don't know how much that even effects performance though.
03-19-2007, 03:27 PM #7
what pumps it? a pump, or vacume?
03-19-2007, 03:43 PM #8Senior Member
- Jul 2005
- Jacksonville, FL
An electrically activated pump - follow the hose down to below the drivers side headlight area.
03-19-2007, 03:44 PM #9
thanlks , seems like there a few that goes up the hood towards tha tdrive where does that go
03-19-2007, 03:57 PM #10
i shouda gotten rid of it when it was dead, instead of getting a new one put in for 700 bucks, DUMB ASS
03-19-2007, 04:01 PM #11
03-19-2007, 07:55 PM #12
03-19-2007, 08:10 PM #13
03-20-2007, 12:05 AM #14
03-20-2007, 04:33 AM #15
thats an expensive lesson...
03-20-2007, 04:41 AM #16
i think it was actually 400 but still expensive, hey i dont mind having it, better to have everything working as GM designed.
03-20-2007, 04:48 AM #17
03-21-2007, 09:54 AM #18
During my LS6 intake yesterday, we removed the AIR system too. However, I left a rubber hose coming out of that hole and it ends around the aread that is parallel to the brake resevoir. I plugged the hose with an old lug nut key.
Is everyone else ripping all that shit out? Even whats under the driver side headlight?99 T/A M6
LS6 intake, Hooker Coated Long Tubes, Y-pipe w/1 carsound cat, Hooker Catback, MTi Clear Lid, FRA w/ Holley Power Shot, ASP crank pulley, 1.8 RRs, 3.73s w/TA girdle & Eaton Differential, Granatelli SFCs, Pro 5.0 Shifter, LS6 Clutch, Diablo, TByrnes Maf Ends (in winter), All the Free Mods
03-21-2007, 10:01 AM #19
03-21-2007, 10:19 AM #20
Ok, is it a bitch to rip out? Do I get it from under or over?
what kind of damage am I looking at?
By LeadFarmer in forum Automatic TransmissionReplies: 5Last Post: 05-07-2011, 11:00 AM -
damage repair
By sidws6 in forum Firebird / WS6Replies: 3Last Post: 03-30-2011, 03:20 PM -
Help: help with some damage on my ram air hood
By augie1209 in forum Appearance SectionReplies: 3Last Post: 01-04-2011, 08:36 PM -
Rim chemical damage hlp!
By [email protected] in forum Showcar and DetailingReplies: 9Last Post: 08-21-2010, 01:29 AM -
Pro's of removing the EGR system on a 98 z28 ?
By 98Z28importslayer in forum External EngineReplies: 5Last Post: 05-01-2008, 09:41 AM
