Thread: methanol injection
03-16-2007, 11:16 PM #1
methanol injection
Hello
I am a F-body methanol injection specialist
Any ? , or need info or help , let me know
03-18-2007, 12:59 PM #2
Anyone need help or have questions let me know
03-19-2007, 07:25 PM #3
What would it do to my car if I just hooked it up on there without tuning for it? If you even need a tune for it? I have the STS turbo on my car with the Devils Own meth kit on it right now. We didn't need it for the tune I did because I'm only running 5 p.s.i.(wanted to keep it safe) Would it help me or what?
Jimmy
03-19-2007, 11:53 PM #4
Tuning in a progressive methanol injection system on a Dyno Jet will yeild more power , and allow you to add more timing even if you keep the boost at 5-6 psi Your turbocharged motor should be leaned out on injector and add in the methanol to make up for the Fuel taken out. This will add extra protection, from the higher octang found in methanol, also the cooling benefit of the intake air inlet charge.
Ok if you already have your car tuned for 5psi then adding a methanol injection system will richen up your A/F ratio. I was running my LS1 like this for about a year, it will work fine just make sure you have a good A/F wide band gauge in your car so u can see how much your methanol system is riching up your A/F as you turn it up and tune it.
It realy depends on where your A/F ratio is on injector , once you know that you can adjust you methanol system to add methanol , depending on how rich you want to run her,
Let me know your A/F on injector, maybe i can walk you through a tune.
Also is your methanol system Progressive? and fully tunable?Last edited by LS1injection; 03-19-2007 at 11:55 PM. Reason: added info
03-20-2007, 12:00 PM #5Junior Member
- Nov 2006
- las cruces nm
silver- 1999 z/28
is there a special type of washer fluid i can use? i have the coolingmist adjustble kit and sts turbo kit but i want to make sure the meth is working correctly before running 8psi. thanks
03-20-2007, 03:49 PM #6
I use VP M1 race methanol straight, best in the industry!
03-22-2007, 03:09 AM #7
EZ EFI Fuel Injection System - Fuel-Injection Interjection
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 06-06-2013, 06:20 PM -
Water/Methanol Injection - The 50 Percent Solution
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 05-28-2009, 09:30 PM -
Water/Methanol injection ?
By 9t8z28 in forum Forced InductionReplies: 67Last Post: 02-24-2009, 02:13 PM -
Methanol/water injection systems good or bad
By Dillard99 in forum Camaro / SSReplies: 1Last Post: 04-25-2007, 01:54 PM
