Thread: sticky clutch
    I need some money huggerls1's Avatar
    Feb 2007
    chandler az
    hugger orange
    1999 camaro ss
    sticky clutch
    has anyone ever experianced this. my clutch pedal will get stuck almost all the way against the floor and ill have to get my foot underneath it to bring it back up, pump it a couple of times then it will be fine. it happnes quite often for me. any body know
    Member Z28_SS's Avatar
    Florida
    98 SS Camaro
    st asked my dad and he said it sounds like the slave cylinder
    Marylandistan
    2001 Trans Am (sold)
    Slave or just air in the hydraulics.
    Feb 2007
    San Diego, CA
    2002 Z28 A4 NBM
    Sadly now demodded :(
    Quote Originally Posted by INMY01TA View Post
    X2. Several guys with M6's in the car club I belong to have experienced this.
    Feb 2007
    chandler az
    hugger orange
    1999 camaro ss
    what is the slave cylinder and is it bad or do i just need to do something to it?
    Marylandistan
    Quote Originally Posted by huggerls1 View Post
    You could try having the clutch bled, if that don't work then I'd just replace the slave. Doing the drill mod while bleeding the clutch wouldn't hurt either.
    Senior Member JonB's Avatar
    Florida
    2005 GTO
    Is your fluid in your resivior black? If it is I would look into replacing the master cylinder first. Well actually I would bleed the system first. Then the master then the slave. The slave is inside the tranny so the whole tranny would have to come out to replace it.
    Member 89LX's Avatar
    East Coast North Carolina
    Navy
    2000 Z28 M6
    Master Cyl
    I had the exact same problem and it took replacing the Clutch Master Cylinder to fix. No amount of bleeding or fluid replacement worked for me.
    2000 Z28 M6, SLP Lid, SLP Bellows, SLP UD,
    P&P Maf, TB By-Pass, PS Shorties, LS6 Intake, FAST 78mm TB, Hooker CB, Hurst Billet, Front Tower Brace, small 218/218....527/527....114 cam.
    337rwhp/348rwtq
    Feb 2007
    chandler az
    hugger orange
    1999 camaro ss
    how much did that cost?
    Florida
    2005 GTO
    A stock gm runs about $150 check out fred beans there a sponsor here thats where I got mine.
    houston
    i still have the same prob...i changed my master. fixed it for a day or two and back to the same thing. so i took it to a shop to see if they could maybe bleed it better than i did with a vacuum or somthing but still not working and they wanted to change the master that i had just changed. so now its in a diffrent shop and i told them just give it back when its fixed.
    Feb 2007
    chandler az
    hugger orange
    1999 camaro ss
    well thats going to be me, my clutch actually went out on sat night,so im going to get a new clutch and hopefully they know how fix the other probs, besides the burnt clutch now.there goes a grand or so, they tell me about 500 just for the labor for a clutch install
  1. Do I have sticky clutch!?
    By Maro SS in forum Manual Transmission
    Last Post: 05-05-2010, 08:59 AM
  2. Sticky clutch pedal? Makes car stall...
    By AKIRA in forum Manual Transmission
    Last Post: 03-03-2008, 12:38 PM
  3. Clutch pedal sticky? Car stalls..
    Last Post: 02-17-2008, 06:09 AM
  4. Replies: 21
    Last Post: 12-13-2007, 07:41 PM
