Thread: Foglights
    Impounded MikeSomething's Avatar
    Old Bridge, NJ
    Pewter Metallic
    '00 Z/28
    Foglights
    I made a mistake the other day of ordering new foglights and I didn't read the entire description but the ones I ordered are 54w and the stock ones are only 37.5w... Will the 54w bulbs burn up my wires or cause any problems?
    Old Bridge, NJ
    Pewter Metallic
    '00 Z/28
    Come on guys, someone's gotta know!!! LoL.
    Rock-n-Roller White Rascal's Avatar
    OHIO Go Buckeyes!
    '07 Trailblazer LT
    Are you just replacing the bulbs? If so I would think that the wiring would be fine but the lens and housing might be in danger of melting. If it's a complete foglight replacement you're doing I doubt you will have a problem.
    Old Bridge, NJ
    Pewter Metallic
    '00 Z/28
    Quote Originally Posted by White Rascal View Post
    Just the bulbs man... An electrician told me as long as a have a 9amp fuse and 14gauge wire I should be ok, but it doesn't sound right to me...
    OHIO Go Buckeyes!
    '07 Trailblazer LT
    OK, man
    This is the formula for calculating power...
    P = I x V
    P = Power in Watts
    I = Current in Amps
    V = Volts
    To calculate the current draw you use the following formula...
    P/V = I
    So if you plug in the values....
    37.5W / 12V = 3.12 Amps
    For the new bulbs it would be....
    54W / 12V = 4.5 amps
    Both are well within the fuse's 9 amp rating. Although I've never heard of a 9 amp fuse before.
    You still may melt the foglight lenses with the higher powered bulbs.
    Old Bridge, NJ
    Pewter Metallic
    '00 Z/28
    Well, I meant below a 10amp fuse. Sorry man... Thanks for the info, I'm thinkin of just forkin out the dough for the HID kit for the fogs...
  1. hallo foglights
    By barryz in forum Appearance Section
    Last Post: 03-01-2011, 09:50 AM
  2. New foglights
    By Sas in forum Firebird / WS6
    Last Post: 08-30-2010, 11:08 AM
  3. foglights as drl's?
    By swisscheese in forum Stereo and Electronics
    Last Post: 01-15-2010, 01:43 PM
  4. Question: Anyone with aftermarket foglights?
    By JoshieDoom in forum Firebird / WS6
    Last Post: 12-31-2008, 09:03 AM
  5. foglights for the GTO's.......
    By 0rion in forum GTO
    Last Post: 02-18-2008, 08:37 AM
