    Senior Member
    rochester,ny
    pewter
    2001 z28 lingenfelter 383
    17 x 11's!!! offset??
    what offset should u be looking for when picking out 17 x 11s for the rear.....im looking at some with a 63mm offset..will these fit running 315s without any mods to my car? thanks
    Jun 2002
    Montreal, CANADA
    triple-black
    2000 CamaroSS convertible
    you'll need at least a 1/2" spacer if not a bit more.
    Eugenio_SS
    Senior Member
    rochester,ny
    pewter
    wow or else? they would rub on the inside fender? what is the ideal offset so they just barely dont rub on the inside but dont stick out rediculously far? thanks
    Stang Reaper LS1Formula01's Avatar
    Missouri
    Pewter Metallic (1of?)
    2001 Formula M6(1 of 225)
    then why are you going with 17x11s if you don't want them to be to far in or out? there's only so much room in those fenderwells and 17x11s are stick out to an extent no matter what......
    Senior Member
    rochester,ny
    pewter
    want them to fit as best possible bro....there fikse wheels...u dont buy expensive wheels that dont fit perfect..i want 315/35s on the rear for more traction....as u can see in my sig that has been a prob for me...i LOVE the way 315s look on the rear of an fbody ....i dont want them miles out past my rear fenders though if they dont have to be ....itll look like one of those hoodrat mustang 5.0s with wheels 6 inches past the fenders..
    Jun 2002
    Montreal, CANADA
    triple-black
    Quote Originally Posted by tonyjnjz View Post
    pretty much +50mm... that's what i have as well as lots of people.
    Senior Member
    rochester,ny
    pewter
    so they would sit 13 mm to far IN....and rub hard....thanks
    Missouri
    go with a 17x10 wheel with a 295/35 tire
    Senior Member
    rochester,ny
    pewter
    u mean 18 x 10 with a 295/35 tire? z06 size ...not sure they make many tires in size 295/35/17
    Member luciangage's Avatar
    tennessee
    94z
    i have 17x11 and they look great and they dont rub
    tennessee
    94z
    oh if it helps 315/35/17 on back 275/40/17 on front different offsets not sure what but can send pics and offset if you wish
    Junior Member bowtiepwr's Avatar
    western Massachusetts
    1994 Z28
    >AFS wheels sells the correct offset for the rears if you want to go with 315/35ZR17 and 275/40ZR17 for the front.
    They have pics on their site http://www.afswheels.com/Shop/Contro...1368/set_num/1
    BTW they are cheaper on Ebay from them too.
  1. Different offset on 15's
    By TA98 in forum Wheels and Tires
    Last Post: 03-27-2011, 06:47 AM
  2. Please help w-offset ?
    By ZR28YELLOWJACKET in forum Wheels and Tires
    Last Post: 05-24-2007, 08:09 AM
  3. Need help with offset
    By RDS in forum Wheels and Tires
    Last Post: 11-28-2006, 02:00 PM
  4. Help with offset
    By bwinch in forum Wheels and Tires
    Last Post: 05-30-2006, 09:24 AM
  5. Is this offset ok to use?
    By NavyZ in forum Wheels and Tires
    Last Post: 03-25-2006, 10:12 AM
