Results 1 to 20 of 20
Thread: New Toys
03-10-2007, 11:47 AM #1
New Toys
We're installing them this afternoon. Coolness.
03-10-2007, 01:58 PM #2
Sweat !!! I use them on the front. #1 for the track, then crank them up on the street !!! Have Fun !!!
03-10-2007, 02:11 PM #3
Can you make any suggestions about adjusting them? Street and Strip
03-10-2007, 02:23 PM #4
I keep the fronts both on 1,the left rear 6, and the right rear on 7. Due to launch twist. I also installed the anti roll bar that replaces the rear sway bar.
03-10-2007, 02:27 PM #5
Thank you. I don't have the anti roll yet but hopefully it won't be too bad. I don't think I'm going to be practically standing like you are
03-10-2007, 02:28 PM #6
What do you change it to for the street?
03-10-2007, 02:33 PM #7
Just take the fronts up to like 7 or 8... You'll be able to tell when driving on a dippy road. If you leave them soft ( #1 ) you will bottom out the front. That hurts the ol feelings !!! Are yours QA1 ro QA1R ???
03-10-2007, 02:42 PM #8
OOPS, QA1 or QA1r ??? The QA1r has the 10-90 settings. I run the QA1...
03-10-2007, 05:45 PM #9
03-11-2007, 04:03 AM #10
So, How did the project go ? I remember waisting my old shocks & springs in the front...
03-11-2007, 10:28 AM #11
Only got the rears on last night went well. Working on the fronts now and I see whatcha mean about wasting them. I post when they are finished.
03-11-2007, 05:47 PM #12
All done. Gotta adjust the ride height in the front (too High) but I took it for a spin and I really them! Going to the track on next Sunday I'll tell ya how it goes. Thanks for the help.
03-11-2007, 07:27 PM #13
Sounds Excellent ! Do you have a set of drag tires for the back ? I run the M/T Drad Radials with 21 lbs of air presure & very pleased with them. Those QA1's are realy going to help your weight transfer !!!
03-11-2007, 07:38 PM #14
I have Centerline ConvoPros Front & Rear and Run 26" MT Slicks in back and 26" Mickey Sportsman 4" wide in Front. I've been running on these for about 9months. I really like them. The Convo Pros were a Valentines present from my Hubby last year. Gotta luv my Hubby for puttin up with me.
03-11-2007, 07:46 PM #15
I just found the speed shop photo of the car !!! Looks Good !!! I also run the convo pros & know how much grinding off the brake calipers you went through ! If you get a chance, try the radials. They are heavier, but your 60' will improve alot. I'm hitting mine with a 4600 stall & 4.10 gears. Stock cubic inch motor & 150 dry shot. Alot of bolt ons. High 10's!!!
03-11-2007, 08:09 PM #16
Yeah I really like the convo pros. I was runnin Weld's they sux. So you think the slicks are slowing me down? I have another Monkey on my back I gotta worry about. I've broken the rear 2+ times. Right now theres an Eaton Pro and Richmond 3.73's but it's not too much longer for this 10 bolt. Did you change the rear to a Moser?
Thanks 4 the help.
03-11-2007, 08:17 PM #17
After the 4'th time I blew the rear, I did go with the moser with the spool. I kinda wish I went with the posi unit because the spool drags the tires around turns. If you go that rout, you will want to add the adjustable control arms. The moser didn't bolt up centered. I couldn't bolt my 28" tires on until I adjusted the rear end forward. But, It is bullit proof !!!
03-11-2007, 08:21 PM #18
These the pics you are talking about?
It's been a work in progress but I have loved every minute of it.
03-11-2007, 08:26 PM #19
Yeah already decided on the posi. I'll be running 26" so maybe I won't have that prob. I run mosly 1/8th mile 28" slow me down in that short a run.
03-11-2007, 08:33 PM #20
Feels like spring is almost here and I'm getting the itch to go to the track !!! I mounted the tripple pillar guage pod today... Nos presure, fuel pres, & wideband 02 guage... That too, was alot of work ! Did take it out on RT 30 and blow some cob webs out of her !!!
New Toys ^.^
By Draik in forum Firebird / WS6Replies: 3Last Post: 03-02-2011, 08:33 AM -
Fast Toys!
By blackSS01 in forum Sponsor FeedbackReplies: 0Last Post: 05-12-2010, 10:09 PM -
Question: Fast Toys Ram Air Kit
By camarodude48 in forum External EngineReplies: 2Last Post: 02-18-2010, 10:01 AM -
My Other Toys
By WikdWs6 in forum Member's RidesReplies: 4Last Post: 09-29-2009, 03:37 AM -
toys
By FTI in forum Member's RidesReplies: 0Last Post: 03-30-2007, 06:10 PM
