03-09-2007, 06:05 AM #1Junior Member
- Feb 2007
- Shreveport, La
- iTrader
- 0
black, red, green, white- 93/99 -under construction
lt1 harness and computer for auto
Does anyone have the whole harness or atleast the transmission harness and computer for an auto.
03-09-2007, 09:52 AM #21 bad mofo
- Aug 2006
- lake jackson
- iTrader
- 0
black,blue,red- 97 lt4 ws6,98firehawk,91z
what year, obd1 or obd2
03-10-2007, 02:06 AM #3Junior Member
- Feb 2007
- Shreveport, La
- iTrader
- 0
obd1 for a 93 but cant i just switch over to obd2?
03-12-2007, 08:21 AM #41 bad mofo
- Aug 2006
- lake jackson
- iTrader
- 0
in 93 thay used proms you need a 94/95 complete harrness if you use and obd2 96/97 it involves more sensors (crank, o2's timing cover ect.. ) use the obd1 for simplicity. obd2 people swich to obd1 ecm's but the ecm must be reprogrammed to work but wont pass smog and if you have an auto you need an auto harrnes and ecm but an auto harrness can work with a man trans. but the ecm will need to be for a man or it will throw codes unless it's reprogramed. if its the stock trans (auto) is a 700r4/4l60 not 4l60e so that will need to be changed. you may be able to use a man ecm ceep the 700r4/4l60. If you swich to a 4l60e the pump (pwm or not) need to mach the ecm. pwm meens pulse with modulated i think pwm cam in, in 96 with obd2. Hope this all helps, post what you need
03-12-2007, 08:48 AM #5Junior Member
- Feb 2007
- Shreveport, La
- iTrader
- 0
well i guess i need a 93 obd1 for a 4l60e, i already have a 93 manual harness and ecm. can i use a 700r4 with that ecm, or do i need somthing to control the lockup?
03-12-2007, 07:51 PM #6Junior Member
- Feb 2007
- st louis
- iTrader
- 0
i have a ecm from a 94 Z28 A4. let me know if intersested.
Question: Need: computer/harness help LS1 / 4L80E
By captain in forum Computer & TuningReplies: 0Last Post: 05-08-2015, 04:34 AM -
Question: Computer/harness issues
By Julius in forum Computer & TuningReplies: 0Last Post: 04-28-2010, 11:39 AM -
How to make an LS1 run without computer and harness
By 19691998firebirdtransam in forum General HelpReplies: 2Last Post: 01-16-2008, 02:20 AM -
99 and up computer&harness for auto tranny
By hotrod393 in forum Parts Wanted / TradeReplies: 0Last Post: 09-17-2007, 08:19 PM -
"02" LS1 w/harness, computer, and auto trans ALL 4 $3000
By BigDaddy in forum Parts For Sale / TradeReplies: 3Last Post: 01-09-2007, 02:02 PM
