Results 1 to 11 of 11
Thread: Mass Air Flow Sensors
03-07-2007, 07:33 AM #1Member
- Jan 2007
- EL PASO TX.
NAVY BLUE METALLIC- 02' WS6 TRANS AM
All Right I Know There's A Ton Of Opinions For These? Are They Really Worth Buying? Do They Really Give You The 10-15 Hp They Say They Do? What Do You Guys Think?
03-07-2007, 08:22 AM #2Just me
- Nov 2006
- Broken Arrow, OK
The stock MAF is good up until 500 HP. The aftermarket ones don't give you 10-15 HP as claimed. There are tons of posts on this, you should do a search on it, but its a waste of your money to buy one.
03-07-2007, 08:25 AM #398T/AformulaGuest
Bigger is always better !!! Whatever you do DO NOT go with the SLP brand it makes my service engine light go on and off like christmas lights, and if you go bigger you could expect 3 ta 5 hp gain 10 ta 15 is pushin it. But aside to that did you ever get my PM on the electric cut out ?
03-07-2007, 10:16 AM #4Member
- Jan 2007
- EL PASO TX.
03-07-2007, 04:45 PM #5
03-07-2007, 04:46 PM #6
your $$$ is better spent else where.
315rwhp 98 SILVER Z28 (3500lbs)- SOLD
400rwhp 99 HUGGER SS (3375lbs)- SOLD
340rwhp 02 YELLOW Z06 (3040lbs)
03-07-2007, 04:50 PM #7Awaiting Activation
- Mar 2006
- LS1 land
yea definetly stay with your stock MAF. When my stocker broke i went with a slp but now am going back to stock for tuning reasons. The slp ones are supposedly a nightmare to tune, and they also lean your motor out which is baddddd!!!!!!!
03-08-2007, 06:15 AM #8Member
- Jan 2007
- EL PASO TX.
So how exactly is it that the MAF works? Isn't it supposed to signal my car to suck in more air? Why is it so bad? I thought more air = more power!!!!????
03-08-2007, 08:22 AM #9Awaiting Activation
- Mar 2006
- LS1 land
it determines the amount of air entering the engine. It then uses that info to calculate how much fuel is necessary.
problem is the aftermarket ones can lean out the engines which isn't good. Yes, leaning it out will probably make some power, but you don't want power from leaning your engine out.
03-08-2007, 10:18 AM #10MOTOR CITY MARO'
- Nov 2005
- LIVONIA,MICHIGAN
PEWTER- 2000 CAMARO SS #3821
The SLP unit is a factory GM piece (Z06) at 85mm so I don't understand the tuning factor? It should tune the same as a stock piece I would think.
03-08-2007, 02:51 PM #11
bad mass air flow
By Black 98 formula ws6 in forum Firebird / WS6Replies: 6Last Post: 09-06-2010, 09:55 AM -
WTB Mass Air Flow (LT1)
By JwMonE99 in forum Parts Wanted / TradeReplies: 8Last Post: 12-21-2007, 03:26 PM -
By samson_420 in forum External EngineReplies: 7Last Post: 11-09-2007, 01:33 PM -
High-Flow Mass Air Flow Sensors
By 2001bird in forum External EngineReplies: 7Last Post: 11-10-2006, 09:02 PM -
Help Ls1 Mass Air Flow ?
By gowad619 in forum General HelpReplies: 4Last Post: 10-18-2006, 06:47 PM
