Results 1 to 16 of 16
Thread: 3.8 speeds
    Member imprtkillr2810's Avatar
    Eastern time zone
    2000 trans am
    Question 3.8 speeds
    hey im just wonderin what the top end on the 3.8L camaros and bird is? anybody kno or have a site i can look at?? and im talkin stock no mods at all?
    Crane, Texas
    1998 Firebird
    118 on the speed limiter. Otherwise around 130-135ish probably.
    Eastern time zone
    2000 trans am
    so they are limited to 118??? any way u can change that?
    LS1 land
    a tuner or a handheld programmer can turn it off or change it.
    Eastern time zone
    2000 trans am
    same on the LS1?? to change the limiter i mean?
    SS#430 1 of 74 7camaro7's Avatar
    Nashville, TN
    02SS6spd VERT!
    I did 120 on my old one.
    LS1 land
    Quote Originally Posted by imprtkillr2810 View Post
    yes, you change the limiter on both V6 and V8 the same way. thought the CPU
    Nashville, TN
    02SS6spd VERT!
    it definitely seemed to me like if there was no limiter that it could've done 150 or at least 140
    LS1 land
    well there are limiters on ones with non Z-rated factory tires.
    Bawlz Deep andrew rs's Avatar
    gold
    2000 honder accord
    i have had the RS up past the 125 on the speedo. idk if that was a true reading or not.
    Nashville, TN
    02SS6spd VERT!
    Those 3.8s have a harder fight against momentum up top but they eventually get it rolling.
    Junior Member Thegr8schlotzky's Avatar
    Jun 2006
    Salem, Oregon
    1996 Camaro
    It really depends what gears you have to figure your actual top speed when the limiter is programmed out. With the Y87 package, on A4, the 3.42s will get you to about 130-135, but with 3.08s you can get past that, probably 140+, it just takes longer to get there.
    Dec 2004
    SS: NBM, tan top
    1998-SS, 2010 Jetta TDI
    Quote Originally Posted by 7camaro7 View Post
    you dont fight against momentum, momentum is in the direction of travel, your car fights against wind / air resistance
    Senior Member nitrox28's Avatar
    Lexingon Kentucky
    1997 Grand Cherokee
    1999 Firebird.
    Yep. Buy a V8.
    Nashville, TN
    02SS6spd VERT!
    Thumbs up
    Quote Originally Posted by ss~zoso~ss View Post
    hahaha, that lil bit of wind doesn't even count, hahaha, I'd say its momentum because it has to get more of it to get going, fighting against wind would only be to maintain the speed at which the fight begins. Think about it fighting against wind... The wind only gets stronger. At a speed that you're fighting wind, you're pretty much done.
    el paso, tx
    i have a GTP 3.8 supercharged and i topped out a 143mph that shouldn't help you out, but i just wanted share lol
  1. Trap speeds...
    By Lunatikgixxer in forum Drag Racing
    Last Post: 05-01-2011, 03:14 AM
  2. Question: Air pump and low speeds
    By Hot head in forum External Engine
    Last Post: 04-20-2011, 07:05 AM
  3. usb 1/2.0 transfer speeds...?
    By grandkodiak in forum Computers / Gaming
    Last Post: 08-02-2009, 12:10 AM
  4. Shifting Speeds
    By mst219 in forum Camaro / SS
    Last Post: 03-20-2007, 10:20 PM
  5. Top RPM speeds?
    By wicked1 in forum General Help
    Last Post: 04-20-2006, 07:22 PM
