Thread: all light mod
    Member transam98's Avatar
    Herrin, IL
    2003 Ram 2500
    all light mod
    I was getting ready to do this today and my roommate told me it would burn out the fog lights faster. I didnt think it would. He is one of the guys that like to keep everything oem. He doesnt see why i want to do it. I told him to see better with the HI's on and i dont like it when the fog lights go off when u put the HI's on. so if any one can tell me if it burns the bulbs out faster and if it really helps u see better at night with the HI's on. thanks guys
    Door-To-Door Pipelayer DJ Red Barron's Avatar
    West Monroe, LA / Cameron, MO
    86 Buick GNx - Black
    08 Jeep GC SRT8 - SBM
    Quote Originally Posted by transam98
    I guess it's possible that your lows & fogs will burn out faster because they will be used when your lights are on both low & high beam, whereas in stock form, they turn off and save bulb life whenever you run your high beams. But I don't think it's going to hurt anything. Shaving a little life off of your fog/lows isn't too big of a deal.
    Junior Member John2005's Avatar
    Avon Park, FL
    Does it really matter when bulbs are only about $22 for a good set?
    Herrin, IL
    2003 Ram 2500
    what i was really wondering is will it hurt wiring or relays. i dont care about replacing bulbs, i just dont want to ruin my wiring and stuff like that.
    Member my1973form's Avatar
    Az
    SOM
    2002 Formula Firehawk
    All to wiring to the headlights already can handle the current w/o burning-up (independent wiring); unless you install higher wattage lamps which will draws more current and could burn up wiring and possible smoke the relay. I can't think of any reason that could cause damage to the circuit having both the Hi/lo beams and fog lamps on all at the same time. This option will only draw more power from the battery and thats ok...
    Herrin, IL
    2003 Ram 2500
    thanks,sounds like i will do this mode at the end of the week.
    Boosted Foolz
    Buffalo
    BlAcK
    1998 FiReBiRd FoRmUlA
    can u send me a link on how to do this mod?
    Senior Member Redphoenix1998's Avatar
    Apr 2002
    San Jose
    1998 Pontiac Trans Am
    PM EVL LS1, he has the write up. I changed my fogs to PIAA 510 fog lamps. Big difference. I do highly recommend that mod as well. I didn't do the all light mod. I haven't honestly, had the time in 4 years If you want to change your lamps for higher wattage H3 bulbs, look at the cyberwhites from wal mart or blazertechs. I went the expensive route and used the 510's but cyber whites are just as good. It does require a simple bracket mod and some wire splicing but it take less than an hour to be honest. The results are definately worth it. Here's the pics on my car. I do have sealed beams for my lows with PIAA H7 bulbs.
    PIAA's installed
    The lamp looks out of center, I did fix it by adjusting the bracket
    Lights on
    Apr 2002
    San Jose
    btw, the color is Ion Crystal
  1. Tail Light, Head Light Lens Cleanup, Body Work Questions
    By MAXX2 in forum Appearance Section
    Last Post: 12-15-2010, 08:15 AM
  2. light up middle tail light bird
    By trans_am7935 in forum Firebird / WS6
    Last Post: 05-28-2009, 07:59 AM
  3. Adjustable Timing Light - Light Up Performance
    Last Post: 03-23-2009, 06:50 AM
  4. C5 Z06 - CAGS light as a shift light
    By rbartick in forum Computer & Tuning
    Last Post: 04-14-2008, 03:26 PM
  5. Bud Light, Coors Light or Miller Lite?
    By Hurley711 in forum Almost Anything Goes
    Last Post: 05-26-2007, 01:21 PM
