Results 1 to 13 of 13
Thread: smog legal cam
03-05-2007, 05:46 PM #1Junior Member
- Nov 2006
- Oxnard CA
Black- 1998 Camaro Z28
smog legal cam
i have a 98 z28 a4 with 104k miles and was thinking of doing a head and cam swap. the only thing is i want to keep it emission legal. i live in cali so this is the strictest test as it is, my car just recenly passed the sniffer test, but i will be moving to arlington texas in about 3-6 months i dont know how strict it is over there. but ive been looking at many cams but none advertise smog legal not even the ls6. so my question is whats the biggest is can go while keeping is smog legal, i love hp and would go for the bigger bang for the buck like texas speeds magic stick #4. but i will also be driving it daily and ocassional strip and maybe some road course action
03-05-2007, 05:48 PM #2Slow'er'Ass
- Thornton, CO
224/224 is about it.
And you need a great tuner.
03-06-2007, 04:52 PM #3Junior Member
- Nov 2006
- Oxnard CA
thanks, what about lift? will .550 do for int and exh. and does lobe seperation play any part in idle quality and drivability. will it have that nice lopey idle?
03-06-2007, 05:31 PM #4
if you want a lopey idle then go with about a 112 lsa bute driveability and idle quality wont be as good. You should go with about a 114 for good driveability and a little ore low end power. You would be good with a 224/224 .550 .560 cam on a 114
03-07-2007, 11:59 AM #5Member
- Jun 2006
- irving
candy red- 98 Camaro Z28
I thought 112 LSA power came in sooner than the 114 LSA and had a bit more torque.
03-08-2007, 05:56 AM #6
Get a z06 cam / head combo. With tune should be pretty legal and will make some power.
03-08-2007, 01:54 PM #7Lift won't hurt you in regards to the sniffer, too much overlap will. I'd recommend speaking with the folks over @ Thunder Racing, as they can grind you a cam with .600"+ lift, 22x duration, be emissions friendly, while making more power to the wheels than you could possibly imagine (thank you, LSK lobes)....
Originally Posted by DANs1998Z
03-27-2007, 08:33 AM #8Member
- Oct 2005
- calif.
Mine passed easily in Calif with a .221 with .566 Lift @ 114 LSA---In hindsight i could have gone slightly more on the duration like mayge .222 or .224--However I don't think any 112 LSA will pass--The more overlap the harder to pass---evry cam is a little different--most 112 LSA cams are pretty aggressive and have lots of overlap to push the HP up higher in the RPM band
03-28-2007, 06:28 AM #9Junior Member
- Nov 2006
- Oxnard CA
thanks. do you have a custom ground cam or is it from a certain supplier?
03-28-2007, 03:27 PM #10Member
- Oct 2005
- calif.
03-29-2007, 05:40 AM #11member since may 2000
- Dec 2002
- n/w chicago
a comp cams 224/224 with a tune will pass.
a few bolt ons, 379 rwhp
11.96 @113.25
03-31-2007, 08:56 AM #12i would call that a waste of time.Get a z06 cam / head combo. With tune should be pretty legal and will make some power.
and i have a Z06.
Im in CA. and i passed smog twice. in my 99SS making 400rwhp.
10.6:1CR ported LS1 heads, 222/224 .566/.568 114 cam and bolt ons.
if i had to do it again.
id go....
11.2:1CR ported LS6 heads or (AFR,TR,DART etc.)
and a 224 580ish 114.,
and with the right bolt-ons you should see..... 425rwhp 400rwtq.
good luck.315rwhp 98 SILVER Z28 (3500lbs)- SOLD
400rwhp 99 HUGGER SS (3375lbs)- SOLD
340rwhp 02 YELLOW Z06 (3040lbs)
03-31-2007, 04:42 PM #13Member
- Oct 2005
- calif.
[QUOTE=M6HUGGERSS;679643]i would call that a waste of time.
/QUOTE]
Would deff go with something better than a stock Z06 cam--After going thru all the truoble of a cam change--believe me you''ll be disappointed if you didn't go at least to a 221/221 @114---the stk Z06 cam i thnk has a 117 LSA which is the big factor in keeping it from making more HP--even though the Duration may be 212/218
California Smog Legal Turbo?
By JAlan in forum Forced InductionReplies: 1Last Post: 08-17-2009, 06:55 AM -
Smog legal???
By nuttyprofessor in forum External EngineReplies: 5Last Post: 08-18-2008, 02:54 PM -
best c5 smog legal cam
By AntsSilverC5 in forum Internal EngineReplies: 0Last Post: 08-12-2007, 11:23 PM -
Smog legal in california ?
By jinxeng in forum External EngineReplies: 17Last Post: 09-24-2006, 09:11 PM -
6.0/4L80E Smog Legal Swap in CA ???
By BB540 in forum GM TrucksReplies: 10Last Post: 06-26-2006, 10:51 PM
