Thread: Coolant Sensor
03-05-2007, 03:28 PM #1
- Feb 2006
Coolant Sensor
I think it's crapped out on my '94 Z28 . I put plent of coolant in it a month ago, and have checked it every 3 days since for leaks or problems, and the only problem I can find is that in the morning, whether its cold or warm the light automatically kicks on. Once I get to work and turn the car off, and then restart it, the light goes away until the next morning. Sooo, what I have to ask is:
1. Is a Chevy dealer the only place to pick up a new one of these?
2. What kind of pricing do they run?
3. Is the process to replace the sensor tough? And if not, how do i do it?
Thank you!!
03-05-2007, 03:38 PM #2
- Jul 2005
- Jacksonville, FL
There not hard to replace, and go bad all the time. Have you checked the coolant level in the radiator when the car is cold? http://shbox.com/1/low_coolant.jpg
03-05-2007, 03:42 PM #3
you can get a replacement at napa, advanced auto, or any place like that. they usually run 20 or 30 bucks. Mine crapped out about 3 months ago and I just unhooked it. wont hurt anything at all as long as you check your levels on the regular. some people take them off and clean them and put them back on and that helps for a while. go to your radiator and it should be about three or four inches down below the cap. you cant miss it. Hope this helps.
03-06-2007, 07:14 AM #4
- Feb 2006
hell, looks easy enough. thanks ya'll !
Low Coolant Sensor on LT1
By danjo11 in forum LT1Replies: 6Last Post: 06-06-2011, 03:04 PM -
Help: engine coolant sensor!!!
By pmolina0436 in forum GTOReplies: 43Last Post: 01-05-2011, 06:22 PM -
Coolant sensor
By F55c6 in forum General HelpReplies: 3Last Post: 06-30-2010, 09:58 AM -
Low Coolant Sensor
By Danger731 in forum General HelpReplies: 4Last Post: 04-04-2008, 09:15 AM -
Coolant Temperature Sensor
By ERICV82GO in forum External EngineReplies: 2Last Post: 07-07-2006, 07:43 PM
