Results 1 to 10 of 10
03-04-2007, 07:49 PM #1
What does an exhuast leak sound like from the headers?
I've heard stories of shorttube headers being notorious for leaking on LT1s... i'm experienceing alot of drivetrain noise i'm not used to since i got cam/heads/rockers etc... but somethin doesnt sound quite right. What does an exhuast leak sound like from the headers? i hear like a really muffled pop that increases with rpm that doesnt quite sound like the rocker noise which sounds more mechanical/metallic then this sound.
03-05-2007, 02:34 AM #2
tch tch tch tch tch tch tch tch tch tch tch tch tch tch tch
atleast thats what mine sounds like leaking from the y lol
03-05-2007, 02:44 AM #3Senior Member
- Nov 2006
- Indianapolis
Right. Sounds like tick tick tick etc. After I installed my headers, I started hearing that sound. I tightened the header bolts a couple times, it made no difference, then I traced the sound to a loose spark plug. It was about 1.5 turns loose, I thought for sure it was a header leak, or something worse like bent pushrod. Double check your plugs, that could be it.
03-05-2007, 01:11 PM #4
mine leaked and sounded like a rapid ticking. it was coming from the EGR delete. but i fabbed a good peice of meatal with a gasket and sealed it up tight. you may also want to look at symptoms of needing a LT4 knock module
03-05-2007, 01:38 PM #5
03-05-2007, 04:38 PM #6
03-05-2007, 04:38 PM #7
i hope you get everything straitened out cause your car sounds like its pretty mean now
03-06-2007, 07:14 AM #8
Yeah, my exhaust leak sounds like a constant tick tick tick. I'm pretty sure its an exhaust leak at the EGR/header connection. I'll know for sure when I try to block it off this spring/summer.
03-10-2007, 05:12 PM #9Member
- Feb 2007
- california
blk- ?
if you use the paper type gaskets. i like to soak them in hot water for awhile and then install them...hand tight then fire it up and let it warm up good and cool down....retighten and they should be good to go for a while with no leaks..any body else ever soak the gasket first??
03-10-2007, 05:37 PM #10
Why would you use the paper gaskets? Those things are unreliable junk. Throw the paper ones out and go by some OE metal gaskets.
Sound Diff Between Equal and Unequal Length Headers
By Shudson105 in forum External EngineReplies: 3Last Post: 03-22-2012, 09:11 AM -
Best Headers for TD exhuast
By supersporter13 in forum External EngineReplies: 1Last Post: 01-31-2009, 05:20 PM -
98 Z28, want headers, What is good for sound?
By johnshuler08 in forum External EngineReplies: 1Last Post: 06-18-2008, 08:37 AM -
AR headers installed pics & sound
By hawk1125 in forum Rocky Mountain MembersReplies: 9Last Post: 09-05-2007, 09:17 AM -
putting BBK headers on my car and looking for a good exhuast, opinions please .....
By jason.fox3 in forum CorvetteReplies: 12Last Post: 04-03-2007, 08:29 AM
