Thread: 3 series or 2 series?
03-03-2007, 02:47 PM #1
hey whats up all can anyone tell me the difference between a 3 series and 2 series. also a buddy of mine has a 97 v6 maro and wants to do gears whats the best to go with for a m5? thanx all
03-04-2007, 08:36 AM #2Member
- Nov 2006
- Earth
The 2 series carrier is for 2.73:1 and possibly 3.08:1 gears while the 3 series is for 3:23:1 and up. I might be wrong about the 3.08:1 ....
As for the 2 vs 3 series rear end - A 3 series differential is shorter from the gear flange face to bearing end on the long side. The 3 series ring gear is thinner than the equivalent gear in a 2 series differential set up. For instance, to use a 3 series ring gear with a 2 series carrier a 5/16" spacer on the flange face is required. This is really hard to visualize without pictures or actually seeing them side by side. If you are looking for performance you will probably want to go with a 3 series. The 2 series is for tall gearing and low rpm, high speed cruising.
03-04-2007, 08:40 AM #3
ok so if i wanted to put 3.73's on i would go with the 3 series carrier? my car has the crapy 2.73's it came with from the factory so it has a 2 series carrier?
03-04-2007, 08:49 AM #4Member
- Nov 2006
- Earth
03-04-2007, 01:14 PM #5
ok how bout my buddy's v6 maro m5 what gearing would work best with the v6?
03-07-2007, 12:35 PM #6
I got 3.73s put in my 2.73 Auto, upgraded to the 3 series carrier as well.
3 series bmw
By camarospade in forum Kill StoriesReplies: 11Last Post: 09-26-2010, 07:04 AM -
Wanted: wtb LSx SERIES
By bryan.k in forum Parts Wanted / TradeReplies: 4Last Post: 03-26-2009, 07:16 AM -
LS series in a GS
By 98ls1t/a in forum Domestics and ForeignsReplies: 3Last Post: 11-29-2008, 06:54 PM -
95 BMW 300 series
By WCTA88 in forum Kill StoriesReplies: 13Last Post: 07-29-2007, 01:51 AM
