03-02-2007, 12:47 PM #1Junior Member
- Feb 2007
- Hoffman Estates, Illinois
Silver- 1997 Corvette
How to program out O2 codes and still pass OBDII emissions test?
I have a 97 C5 with a blower and longtube headers. As long as I have owned the car, it has throw O2 sensor codes. I have even swapped in new sensors, and verified voltage oscillation using Autotap. They seem to work fine, it's just that they take too long to heat up, and trip the code first.
I just received my pink slip (3rd notice) in the mail from the Illinois EPA, so if I don't pass by June 20th they suspend my plates.
I have LS1 edit. There are different ways to "turn off" a code.
There is the "Does error set SES?" toggle box: Options are
- On
- Off
And the "Error Mode" toggle box: Options are
- Type A MIL on 1st error
- Type B MIL on 2nd error
- Type C no MIL light
- Type X turned off
In IL, I believe (please correct if wrong) that the OBDII emissions test scans for a couple things:
- Is the MIL illuminated
- Are there emissions related codes present
- Have readiness checks been completed
I have heard that if you disable the codes in LS1edit the "wrong way" that will fail the OBDII scan because it shows the tests as not-ready, or shows them a disabled.
So the bottom line question is, using the above listed LS1 edit toggle options, how do I tune out these codes so I pass emissions by OBDII scan in Illinois?
03-02-2007, 05:21 PM #2
Off
Type X turned off
this will keep the light off and not report an error.
if illinois is like most states, they check for stored and current codes, along with the readiness tests being complete. anytime you clear codes, it takes about 20 key cycles to get the readiness tests completed.Cold Air Intake, Muffler Delete, Vinci High Performance Dual Valve Springs, Hardened Pushrods, Yella Terra 1.85 Rockers, Some Hydropdipped Stuff, Strut Tower Brace, Some SS Badges, boost/vacuum gauge, fuel pressure gauge, some checkered stripes, drilled/slotted rotors, ZL1addons Stealth wickerbill, Ruxifey LED side markers
03-18-2007, 02:17 PM #3
im not sure about how to keep the car from throughing a code but i do know it takes about twenty min. to set a o2 code, and 3 key cycles. not trying to sound like a smart-ass mrr. it's just that i did state inspec. in tx for about three years. and i believe they only check for readiness, current and past code status. but ther is a loophole, you are allowed up too 3 not ready messages on the emissions test. so if you can clear the codes and and have a way to monitor the readiness status and get other systems to go ready before the o2 system than you should be good..... but check your local laws first on the test procedurs, like i said i live tx.
03-23-2007, 02:24 AM #4Junior Member
- Orange County/(Hudson Valley), NY
Black- '98 WS6 Trans Am
If you want to pass....use O2 Simms...it is the guaranteed way you will pass!
03-23-2007, 06:57 AM #5
03-23-2007, 06:58 AM #6
03-23-2007, 09:25 PM #7Junior Member
Black '98 WS6 Trans AM (A4)
03-23-2007, 09:29 PM #8
Can I tune out codes to pass emissions?
By GottaHaveLS1 in forum External EngineReplies: 13Last Post: 04-03-2007, 08:54 PM -
OBDII Code Deletion and Pass Emissions?
By 89LX in forum Computer & TuningReplies: 19Last Post: 12-08-2006, 05:00 PM -
OBDII Codes
By T/Ajammer in forum General HelpReplies: 5Last Post: 09-12-2006, 10:33 PM -
Will i pass emissions?
By GottaHaveLS1 in forum External EngineReplies: 3Last Post: 05-28-2006, 09:41 AM -
Decipher your OBDII Codes
By Ed Blown Vert in forum Computer & TuningReplies: 0Last Post: 11-16-2005, 03:06 PM
