Results 1 to 13 of 13
    Preferred Member CWW17's Avatar
    Central Illinois
    Black | Black
    '07 Z06 | '98 WS6
    Which Yank Stall To Buy?
    I have a 98' T/A, 2.73's, Lid, Filter, Cat-Back, and looking to do my first real mod. I've been reading up and decided to go with a Yank Converter due to the tight feel and overall quality of their converters. What stall should I go with? I was thinking 3200, it seems like a good mid range stall to me... Also what all will I need done along with the converter install? Also I may eventually upgrade to 3.73's... Thanks in advance for the help!
    Dec 2002
    n/w chicago
    2000 nhra edition formula
    the 3200 is a good stall. with a stall, youll need a shift kit and a trans oil cooler. a converter tune would also be a plus.
    ls1speed.com does great work in our area
    a few bolt ons, 379 rwhp
    11.96 @113.25
    Central Illinois
    Black | Black
    '07 Z06 | '98 WS6
    price?
    Member Transam388's Avatar
    Cypress, TX
    98 Trans AM
    I had a Yank 3000 stall and the quality is good but at least on mine it seemed like the stall was rated higher than it really was. I personally would say go with like a 3400 to 3600 stall. Might be slightly high if you just want a little more out of your car but I hate to see you spend the money and then have to go and do it again.
    The advice about a tranny cooler is VERY good!!! Make absolutly sure you install a cooler. The coolers are fairly cheap at around 50 to 75 depending on manufacturer. The Trans-Go shift kit is one of the most popular and is good quality and those go for around 100 maybe a little more or less depending on where you get it.
    98 T/A: HPE 5.3 Heads, 238/242 113 cam, Kooks 1 7/8 stepped LT headers, Custom Y pipe, Cut out, Borla, NW 90MM TB, FAST 90MM Intake, TB Bypass, Under Drive Power steering and Crank, 150 Dry NOS, Yella Terra rockers, 3400 TC, HPE tuning,
    ORNGP33L 1BADDLS1's Avatar
    Long Island, NY
    Hugger Orange
    1999 Camaro Z-28
    trans cooler is a MUST HAVE if not say bye-bye to the trans
    also get good fittings and stainless steel braided lines (or have hard lines made)
    rubber lines are a serous chance... have one blow and not realize it and no more go for you
    shift kit is not neccessary... depends on preference...
    personally i believe in doing with out then doing the shift kit later if you feel its neccessary
    or wait it out and have the entire trans beefed up when its neccessary
    torque managment will need to be removed too...
    and do ALOT of reading pertaining to allowing someone to adjust your line pressure... too much and again... bye-bye tranny
    get a 3600 yank
    the higher the STR the more street friendly & harder it hits the tires
    Dec 2002
    n/w chicago
    Quote Originally Posted by cww17 View Post
    price?
    www.ls1speed.com
    Central Illinois
    Black | Black
    '07 Z06 | '98 WS6
    Thanks fellas for the advice and info
    Blown, Stroked, & Sprayed
    Ed Blown Vert's Avatar
    Aug 1999
    No Where
    383 Procharged & N20 Vert
    Smart call to do the converter before the gears.
    Forged 383 | ATI D-1SC
    NX MAF Kit | 222/226 .585 115
    AS Stage II 6.0L FI Heads
    Aug 2006
    29 palms
    2000 pontiac TA vert
    yank PT4400 and call it a day
    Glen Carbon, IL
    At a minimum an SS3600
    Gulfport
    2000 trans am ws6
    Quote Originally Posted by Ed Blown Vert View Post
    Why is it smarter to do converter before gears?
    I just ordered my SS3600 and I have 3:73s Yank said there gonna work great together so if you go 3:73s(I would) go with at least the 3600ss.
    Likes twisty roads bene's Avatar
    England but from TX
    Light Pewter Metallic
    2K Camaro Z28
    I did Yank ST3500, 3.42 gears, hayden tranny cooler and a tune. Car acts like its stock but going from a dig or whenever the car is a beast.
    England but from TX
    2K Camaro Z28
    And btw, no more dead spots.
  1. 3600 Vig or Yank Stall
    By CWW17 in forum Parts Wanted / Trade
    Last Post: 05-11-2007, 06:08 AM
  2. yank 3300 stall
    By mglangley21 in forum Automatic Transmission
    Last Post: 05-06-2007, 11:13 PM
  3. yank 3300 stall
    Last Post: 05-04-2007, 06:03 PM
  4. WTB: Yank 3200 Stall
    Last Post: 12-11-2006, 10:18 PM
  5. Yank 4000 Stall
    By silverstreak_ws6 in forum Parts For Sale / Trade
    Last Post: 04-11-2006, 12:26 PM
