    Feb 2007
    estonia
    1999 Trans AM WS6
    bolt order to place heads
    hi, someone knows where to get information about head bolt order and and tightning strenghts?
    Member lrader99's Avatar
    NW Georgia
    flat black
    autozone, napa, or GM dealer, they are torque to yield:
    Torque pattern:
    F 15____ 13____ 11____ 12____ 14
    R
    O 10____ 3_____ 1_____ 5_____ 9
    N
    T__ 7____ 6_____ 2_____ 4_____ 8
    -tighten bolts 1-10 first pass in sequence to 22 ft lb
    -tighten bolts 1-10 2nd pass in sequence an additional 90 degrees
    -tighten bolts 1-8 90 degrees and bolts 9 & 10 to 50 degrees in sequence
    -tighten bolts 11-15 to 22 ft lb begin with 11 alternating side to side working outward
    **very important...get a thread chaser and clean out the head bolt holes from the factory they have loctice on them you need to clean out all the crud or you will not get a proper torque rating and could possibly damage a thread
    Junior Member slpws6ta's Avatar
    florida
    05 gto impulse blue
    00 WS6 custom paint
    if you didnt already know. you need to get new head bolts gm sells kits you need one kit per head they are like $20 per kit and the part # is 12498545 DO NOT REUSE YOUR OLD BOLTS. Also make sure you use compressed air to blow out the bolt holes with compressed air. If there is water, coolant, oil, anything down in those hole you will crack the block. Get some moly lube for under the head flange. thats the right way to do it.
    florida
    05 gto impulse blue
    00 WS6 custom paint
    I just put my motor back in 2/7/07 after I did afull overhaul myself, just take your time that the best thing you can do
    00 ws6 m6 hurst
    slp loudmouth
    slp lid w/ k&n
    comp cam 224 int. 224 ex. .585 lift 114 lsa
    ceramic coated long tubes w/ ORY
    ls7 clutch with fidanza flywheel
    free mods
    Mickey Thopson 26x11.5R17 ET STREET
    Junior Member greenvilleTA's Avatar
    Greenville, TX
    98 Trans Am
    I just finished building my motor as well...here's a good tip I found and am passing it on. Once you finish your 1st torque pass of 22 ft lbs, get a felt-tip marker (like a sharpie) and make a mark on the head of each bolt...preferrably at the 12 o'clock position. This makes it much easier to know when you've hit 90 degrees on the 2nd and 3rd pass...as well as the 50 degree bolts. Trust me, if the motor is in the car, you won't be able to turn the torque wrench an entire 90 degrees on all the bolts and the mark keeps you oriented...especially on the rear bolts
  1. Header bolt pattern/order?
    By grandkodiak in forum LT1
    Last Post: 08-19-2009, 02:12 PM
  2. best place to order windowmotor?
    By barryz in forum General Help
    Last Post: 06-04-2009, 10:25 AM
  3. Found a place to order ''Cases'' Of CD2
    By Sarge91 in forum Showcar and Detailing
    Last Post: 03-29-2009, 06:05 AM
  4. Need a good place to order a PC.
    Last Post: 09-10-2006, 04:22 PM
  5. Looking for a good place to order motorcycle parts...
    Last Post: 07-06-2006, 09:07 AM
