Results 1 to 19 of 19
Thread: My Door Panel Crack Pic's
02-24-2007, 02:55 PM #1
- Nov 2006
- texas
red- 2001 formula
here are the pic's of the door panel cracks in my 2001 formula. They appear to be a little longer in length than the other pic's. The car has 136K on the odometer.
02-24-2007, 02:59 PM #2
- So Cal
99FRC,00TA,98Formula- 91Firebird,88FieroGT
mine are worse than that and I only have 68K
02-24-2007, 03:14 PM #3
mine arent cracks yet (knock on wood
) but you can tell theres alot of stress in a couple places down the door pannel.
02-24-2007, 04:44 PM #4
02-24-2007, 07:33 PM #5
pull the staples.... ok it could be because im tired but that made absolutely no sense to me lol
and i'm a bit north of charlotte, like 4 minutes from concord mills mall at 49 on i-85. i dont think youre too far away from me! where are you at in statesville?
02-24-2007, 07:44 PM #6
- Thornton, CO
Those look the ones on my 1999.
Mine only has 33,400 on the clock.
02-25-2007, 02:46 PM #7
That sucks. Why do they crack like that?
02-25-2007, 03:22 PM #8
On the back side of the pannel the black rubber window seal is held on by staples. You must pull the third staple from the back of the pannel( back is the outter most part of door when open) The staples are different from the 93-97 in which they add stress causing the plastic to split. Use can use hot glue or simaliar after removing the staple.
I live 20 mins North on 21 outside of city limits.
02-25-2007, 05:25 PM #9
02-26-2007, 06:42 AM #10
I never had one do that! Must be the sun or heat.
02-26-2007, 07:09 AM #11
- Nov 2006
- Missouri
Pewter Metallic (1of?)- 2001 Formula M6(1 of 225)
My 01 has a hair over 70k, and have been like that for the past year. It's one of the common symptoms that all our f-bodies face sooner or later.....
02-26-2007, 07:25 AM #12
02-26-2007, 10:55 AM #13
My cars a 94, 115k or so... no cracks, or just the newer ones?
02-26-2007, 11:00 AM #14
02-26-2007, 12:21 PM #15
Got the samething on my 01.....doesnt bother me too much.
02-26-2007, 07:37 PM #16
- So Cal
I believe it is only on 97+ I have never seen them on an early fourth gen. I also have a 96 formula and it has no cracks. This is not a problem for the Camaro.
02-26-2007, 10:06 PM #17
- Sep 2006
- Smithtown NY
White- 1999 T/A
typical
02-27-2007, 08:21 AM #18
the more you use your windows the worse it seems to get and i thinkit is only a pontiac problem i dont see it on camaros, but they have pletty problems of their own im sure...never heard of the stable theory...too late mine are already cracked now but mine dont look as bad as some of yalls and ive got 124xxxon my door panels
02-27-2007, 09:25 AM #19
Mine have all been 93-95s, so must be the newer ones only.
Door Panel Crack Fixed!
By atmrestyle in forum Appearance SectionReplies: 2Last Post: 08-07-2013, 05:11 PM -
Door panel crack
By johnfin in forum Firebird / WS6Replies: 5Last Post: 04-20-2013, 02:27 PM -
explanation on why our door panels crack
By shady milkman in forum General HelpReplies: 41Last Post: 02-14-2009, 04:57 PM -
Firebird Door Panel Crack Repair - Door Panel Pandemic
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 10-18-2007, 10:50 AM -
Anyone know why the panel right under the windows crack?
By JehalinTA in forum General HelpReplies: 41Last Post: 02-23-2006, 12:34 PM
