    Feb 2007
    Atlanta
    94 z28
    intake questions
    i pulled the engine out of my 94 z puttin the lt4 hotcam in there, porting the heads etc..etc, what do i need buy as far as injectors, throttle body , etc..
    Aug 2006
    Missouri
    94 Camaro Z28
    Stock 24lb injectors should be fine. And the stock 48mm throttle body can stay, but you can have that ported to 52mm if you want.
    Member jasonisdn's Avatar
    nc
    96 ss
    Quote Originally Posted by kevinboy View Post
    if you have alot of miles on the car , buying new injectors won't hurt. just buy some flow matched and make sure to have the car tuned. a larger size isn't needed though.
    Feb 2007
    Atlanta
    94 z28
    if i were to buy bigger injectors/tb how much hp?
    nc
    96 ss
    injectors don't make more HP. they just make sure you get enough fuel to match the amount of air coming in, via the computers senor readings. a bigger TB won't add power UNLESS you can use the extra cfm. a 52 for you will be plenty , the best thing for you to do is tune the car on a dyno after all the new parts.
    Aug 2006
    Missouri
    94 Camaro Z28
    The LT4 Hotcam is a small cam anyways. If you're going to go through the trouble of a cam swap, you might as well go for something bigger. There are even DD cams that will yield more gains than the hotcam.
    Feb 2007
    Atlanta
    94 z28
    ok thanx for the help i , so i can port my tb to a 52 and the injectors will be fine right
    Pistol Pete '96 Z28SS's Avatar
    Cowboy Country Stillwater, OK
    Bright Rally Red
    1996 Camaro SS
    i am running the hotcam now and did not need any modifications to the injectors or TB. save the cash and find something else to spend on.
    --------- Chris - 1996 Camaro Z28SS #1524 ---------
    LT4 Cam Kit | Comp Lifters/PR's | Jet Hot LT's & ORY | Corsa RSC Exhaust | SLP Bilstiens | S-C/D Rotors | 1LE Elbow | !EGR/AIR
    madZ tune | 17x11 Chrome ZR-1's | Berger Panel | Fillins | BMR STB | Autometer A/F & Trans Temp | !Mouldings | Zaino
    Driving as fast as I can dafaic's Avatar
    Waxahachie, TX
    97 TA M6
    stock inj and tb good on the hotcam and the hotcam makes good power. But there are better cams out now that have better street manners and make more power. Since my tune I can fell the cam surge under 2000 rpms which is kind of annoying cause you have to stay in a higher gear or the car goes to jerking if your trying to putt around at 20 or 30mph. It doesn't putt very well it wants to go!!!
    lt4 hot cam, l.e. heads, gold 1.6rr, hooker lts, 3"ypipe, hookercatback, no cats, subframes, b&m ripper, k&n cai, msd6a-coil-opti, udp, tr55 g's, ta girdle, 4.10's, boxed control arms, Madz28 tune, specstg3, alum. elbow. No traction
    nc
    96 ss
    Quote Originally Posted by dafaic View Post
    you need a new tune. check with jeff creech at www.carolinaautomasters.com he can get rid of the surge for ya
    Newport KY
    1995 Chevy Camaro
    If youre gettin porting and polishing, Punch out the intake manifold to 58mm while its off the car. That way if u upgrade your T-body down the road you wont have to remove the manifold to get it ported. Also I saw that you are going to port/polish heads. Make sure u let them portmatch the manifold. A hotcam is a mild cam, but its all up to you and your taste in a cam. A big cam is not for everyone.
    Stock injectors are fine, trust me. The tune is the most important thing in your cam project. A good tune will make you go . Oh and 1 last thing. SPEND THE MONEY on felpro gaskets.
    -Evilt4
    Feb 2007
    st louis
    definatly have everything port matched and if your going to port and polish heads and intake i would definatly buy a 58. let that cam breath that is the most important thing, get headers and catback and a cold air intake. i would aslo reccomened hardend push rods. thats what i did but i got the 1.6 rocker arms and springs on mine. it will run w/out a tune but if you want the power your looking for i would go with a good tune PBJ (PERFORMANCE BY JOE), in
    St. louis
  1. Question: 5.3l intake manifold questions
    By blank94z28 in forum General Help
    Last Post: 06-05-2012, 03:58 PM
  2. Replies: 6
    Last Post: 12-30-2011, 11:40 AM
  3. Questions about the 102 mm FAST Intake
    By 408WS6 in forum External Engine
    Last Post: 12-25-2009, 04:18 PM
  4. Air intake questions.
    By Sarge91 in forum External Engine
    Last Post: 10-13-2008, 09:22 AM
  5. intake questions
    By Bigjohn366 in forum External Engine
    Last Post: 02-29-2008, 03:16 PM
