    Member Jon7I2's Avatar
    Chicago
    99 Formula M6
    Leak Down Test, Faulty Header Gasket?
    Some time ago I had a leak down test done on my car (currently 28,000 miles), and cylinders 1,3,5,7 were all right around 15% which is good. However, 2,4,6,8 were all 28% and above. Furthermore, the 2,4,6,8 were not all within 10% of each other. So my question, can a faulty header gasket cause this? When I did LT's last summer I installed the passenger side header gasket backwards, torque down the header bolts, let it sit overnight, realized it the next day and corrected the problem. Could this action have deformed the gasket to the point that it is causing significant compression leaks in the affected cylinders (2,4,6,8)? Or would this simply have no effect on the compression?
    maine
    2000 ws6
    a header gasket, not possible. It has nothing to do with compression. Its after the exhaust valve.
    Chicago
    99 Formula M6
    alright thanks
    maine
    2000 ws6
    np, good luck figuring i out
  1. Quick Test: Faulty Alternators
    By Ed Blown Vert in forum General Help
    Last Post: 01-14-2014, 08:30 AM
  2. waterpump gasket leak
    By JayTA98 in forum External Engine
    Last Post: 11-21-2012, 08:34 AM
  3. Oil cooler gasket leak
    By bobbyd in forum General Help
    Last Post: 12-25-2011, 08:33 PM
  4. Help: Pan Gasket oil leak!! help help!!!!!
    By denegrader in forum Internal Engine
    Last Post: 05-18-2011, 12:01 AM
  5. Oil pan gasket leak??
    By transamgirl89 in forum Internal Engine
    Last Post: 01-25-2011, 03:25 AM
