Results 1 to 13 of 13
    BlackHawk T/A
    Guest
    Anyone Auto-X with an A4?
    With a stalled A4, and shift points edited to keep the powerband going (no dead spots) how well would it do?
    Jun 2002
    Montreal, CANADA
    triple-black
    2000 CamaroSS convertible
    I think a few guys have tried it... I haven't... so I won't be able to help you.
    auto-x drivetrain/powertrain section
    Eugenio_SS
    Moo cow f**k milk Demon_Speeding's Avatar
    New Mexico...from Kansas City
    2001 Camaro Z28
    IMO you probably wouldn't be too bad as long as you can use the shifter to keep it in the necessary gear, and not let the trans shift whenever it wants.
    BlackHawk T/A
    Guest
    The problem with that is its slow to shift when you tell it to...
    And isn't that bad for it?
    Mrs.'s Boobies
    North Hollywood, Ca
    Onyx Black
    I start out in first and after I get some good high RPMs, I manually shift it to second. After that there is no need (usually) to shift out of second. Most National Champions running an auto use second gear exclusively. They don't even bother with first gear.
    I experimented with changing the shift points, via HPTuners, but that didn't accomplish much. It is just better to do as I mentioned.
    BlackHawk T/A
    Guest
    So it is do-able then? So doing a complete re-work of my crappy stock suspension on an A4 isn't a waste of money? That's basically what I want to know.
    How many MPH will 2nd gear wind out to? I've never checked...
    Also I think a tranny cooler would be a must before putting it through that kind of torture.
    Actually a mod can move this to the Auto-X forum of they wish.
    Jun 2002
    Montreal, CANADA
    triple-black
    MPH should be high enough for pretty much any auto-x track... some tracks are even all 1st gear for the t56 guys... and very rarely you'll hear anyone going in 3rd.
    a4 has also smaller gears in the rear, so I wouldn't worry about top of 2nd gear.
    Mrs.'s Boobies
    North Hollywood, Ca
    Onyx Black
    Yup, most track layouts are under 70 MPH, those are high speed layout. 70 MPH is the top of second gear with 3.23s and a 4L60E.
    Junior Member Raven98Z28's Avatar
    Harker Heights, TX
    02 WS6 M6
    i ran one once in a a4 w/ 2.73s i kept it in first the whole time since the course i drove limited me to speeds less than 50 mph, which equals about 5500 with 2.73s
    Junior Member DrEvyl's Avatar
    North Bend, WA
    Bright Purple Metallic
    '98 Formula & '98 T/A WS6
    Quote Originally Posted by 12secSS
    Actually, you should be able to run it up to around 80-83 mph before hitting redline.
    Mrs.'s Boobies
    North Hollywood, Ca
    Onyx Black
    Quote Originally Posted by DrEvyl
    Oh, sorry what I meant was that 70 MPH is in the upper RPM range of second gear, not that it was the most MPH you can get out of secoond.
    maine
    2000 ws6
    im atleast to 85mph when mine shifts, usually 87-88.... 3.23 rear, stock rev limit
    plenty for auto-x in any case. Maybe my shift points have been edited? know i havnt done it.
    Harker Heights, TX
    02 WS6 M6
    Mine shifts from 2nd to 3rd at 90mph w/ 2.73s at about 6000rpm.
  1. Auto down and Auto up windows?
    By bad idea in forum Stereo and Electronics
    Last Post: 12-23-2013, 04:40 PM
  2. The Best .45 Auto: The Obregon Auto Pistol
    Last Post: 12-07-2011, 05:20 PM
  3. Question: auto, or manual shift auto?
    By mark21742 in forum GTO
    Last Post: 09-03-2009, 05:38 PM
  4. does anyone use the auto dry?
    By greatwhiteZ28 in forum Showcar and Detailing
    Last Post: 09-02-2007, 03:59 PM
  5. F/S - Auto Tap
    By FasstChevys in forum Parts For Sale / Trade
    Last Post: 02-18-2007, 04:46 PM
