    Miami, FL
    What do these codes mean. PLEASE HELP
    I have a 2002 WS6 with a procharger and some mods. My service vehicle light and my service engine soon light are on. I hooked up my predater to read the codes and this is what it gave me.
    1. PO135 O2S Heater Circuit
    Bank 1-Sensor 1 Malfunction
    2. PO140 O2S Circuit
    Bank 1-Sensor 2 No activity detected
    3. P1133 HO2S Insufficient Switching
    Bank 1-Sensor 1
    Does anyone know what i can do to get rid of those annoying lights on my dash. Im not sure what these codes mean. Thanks. Any help is appreciated.
    Ricekiller z28punk's Avatar
    Maple Grove, MN
    2002 Camaro Z28
    1- it means ur 02 sensor isnt heating properly.
    2-the post-cat 02 sensor is not reading anything
    3- i'll have to look that one up, i forget what it means. maybe its not switching lean/rich fast enough? someone will answer it.
    u probably need to replace bank 1 sensor 1 and bank 1 sensor 2
    Arkansas
    99 Trans Am
    may not be connected...
    sensor one may just be bad.. do the live data feature on your programmer and see what millivolts it reads for that sensor
    1 and 3 are common codes with headers, do you have headers? Bosch sensor 13111 are supposed to help with this problem.
    Oklahoma City
    00 LS1, WS6, V8 Gremlin
    96 & 98 GTPs, 64 'Cuda
    Correct that and the others will probably go away.
    Get under there, inspect the connectors and wiring going to your sensors.
    If all looks OK unplug then reconnect them, could be oxidation on the contacts.
    Let us know and we'll go from there.
    Miami, FL
    Thanks. I'll check it out and let you guys know what i found.
  1. Help: p-codes
    By Train in forum General Help
    Last Post: 07-05-2010, 07:30 PM
  2. what do these codes mean
    By jb007 in forum General Help
    Last Post: 05-19-2010, 06:32 PM
  3. codes
    By camaro00ss in forum General Help
    Last Post: 03-31-2008, 10:14 AM
  4. no RPO codes
    By deepblackz in forum Camaro / SS
    Last Post: 11-06-2007, 07:56 AM
  5. New and I need some help with SES codes.
    By mczerwonka in forum General Help
    Last Post: 01-28-2007, 07:46 AM
