    Arkansas
    99 Trans Am
    V Plus Voltage booster??
    Anyone try any of the these? Would using this in conjunction with a fuel pump hardwire kit benefit me when I do my head/cam swap?
    V-Plus Voltage Booster. Your alternator is designed to put out a specific voltage, generally 13.8 volts. The only problem is when there's a greater demand on the electrical system, such as a WOT blast, the alternator falls a little short. The V-Plus is designed to overcome voltage taper at WOT by stepping up the alternator voltage 2.2v. at 70% throttle. Result? More power to your fuel pump and ignition system. Unit plugs in, with no wires to cut or tap into. Includes hardware.
    http://www.lmperformance.com/6768/1.html
    Also could anyone explain how it works? I dont see how it can step up the voltage at the alternator.
    Member Jon7I2's Avatar
    Chicago
    99 Formula M6
    That seems interesting; i would like to see what some others have to say about it.
    Earth
    TTT
    I'd like to hear from someone using one too.
    Blown, Stroked, & Sprayed
    Ed Blown Vert's Avatar
    Aug 1999
    No Where
    383 Procharged & N20 Vert
    I run the Casper unit. It does allow the alternator to put out more voltage.
    Forged 383 | ATI D-1SC
    NX MAF Kit | 222/226 .585 115
    AS Stage II 6.0L FI Heads
    Arkansas
    99 Trans Am
    thanks ed
    OC, California
    1999 Z28 M6
    i got it a couple weeks ago, its a little akward on where to put it but once u have it all hooked up and where you want it, its awesome. raises the volts to about 16 just before red, all the inside lights get bright, ever your headlights look like you turned the brights on. deffinitly works!
    Arkansas
    99 Trans Am
    awesome how long did it take you to put it in?
    OC, California
    1999 Z28 M6
    about 30 min just because you have to get under the car and up to the alternator. thats the only thing that takes so long, the rest is easy.
  1. Question: Hydra booster
    By jiveass in forum GM Trucks
    Last Post: 10-11-2010, 11:06 AM
  2. octane booster
    By bluefields88 in forum General Help
    Last Post: 08-30-2007, 06:14 PM
  3. Voltage booster and stabilizer? Any notice?
    By Z28LS1 in forum External Engine
    Last Post: 08-10-2007, 02:32 PM
  4. Octane Booster
    By Danger731 in forum Nitrous
    Last Post: 03-25-2007, 09:07 AM
  5. msd fuel pump voltage booster
    By 99transamC/FIA in forum Forced Induction
    Last Post: 03-25-2007, 08:40 AM
