Results 1 to 15 of 15
Thread: Will my new wheels fit?
02-22-2007, 04:36 PM #1Junior Member
- Feb 2007
- Oxnard, Ca
Black- 2002 SS Camaro
I just bought new rims and tires for my 02 SS. The problem is i was wondering if my new wheels and tires will fit on my car. A friend mentioned that i might need spacers. I'm not too familiar with with rims and such.. the new tire size is 275/35/18. the wheels are 9.5 also. do i need to buy spacers? HELP!!
02-22-2007, 05:46 PM #2Awaiting Activation
- Mar 2006
- LS1 land
02-22-2007, 06:13 PM #3
I'm no expert, but wouldn't the wheel spacing be a deciding factor?
02-22-2007, 07:49 PM #4Junior Member
- Feb 2007
- Oxnard, Ca
02-22-2007, 08:06 PM #5Junior Member
- Rancho Santa Margarita, CA
Black- 2002 Trans Am
I think it depends on the back spacing of your rims. If I remeber correctly, you want to be in the +35 to +55 mm back spacing range. Someone with better memory or that knows for sure can correct me if I am wrong. If you don't have enough back spacing then you will need a spacer to move the inner sidewall of your tires away from the fender wells.
It also might be helpful to know which rims you have.
02-23-2007, 06:07 AM #6
yes, you would have to make sure that the offset is not greater/less than the stock offset which I believe is 55mm. if so you might have rubbing on the inner fender area. doublre check that though...
also, the stock factory rims were either:
16*8 (z28, Trans Am, Formula)
17*9 (SS, WS6, Firehawk)
17*9.5 is not a stock rim...
02-23-2007, 08:05 AM #7Firebird Encyclopedia
- Oct 2006
- St. Clair Shores. Michigan
Factory
16x8 = 56mm offset
17x9 = 50mm offset
Anything in between 35mm to 56mm will work
The smaller the # the farther out from the inner wheelwell the rim will be.Craig
Semi Retired Street Racer
Gone but not forgoten
NBM `98 Formula M6 HdTp
1 of 1 Build Date 3/12/98
02-23-2007, 03:13 PM #8Junior Member
- Feb 2007
- Oxnard, Ca
Here's the measurements off of the site i bought the rims off of:
18x9.5 inch , 5x4.75 inch 50mm.
Do these sound like they fit?
02-24-2007, 10:09 PM #9
Dude I find that pretty funny but I ask alot of basic questions also and these guys are patient and really cool. You could always ask the people where you bought them if they will fit whatever year car you have if you are still concerned but these guys know their stuff and pointed me in the right direction when I bought my wheels a couple weeks back. Good luck.
02-24-2007, 10:20 PM #10Crazy Canuck !
- Jun 2002
- Montreal, CANADA
Eugenio_SS
02-25-2007, 09:45 AM #11
hey how did you get 17+11 on all four with 315's. You must be able to fly around corners with that set up!!
02-26-2007, 12:59 PM #12
02-26-2007, 01:45 PM #13
right now i have 18'' by 9 1/2'' rims all around i have 245 infront and 285 in rear. i wonted to put bigger tires in the rear how mutch biger can i go with a
9 1/2'' rim ?
Thanks!!
02-26-2007, 02:02 PM #14
02-26-2007, 02:49 PM #15
thats a good idea THANKS MAN!!!
WTT 2002 WS6 Wheels/Tires + Cash For Your Wheels
By Zaccagnini in forum Parts Wanted / TradeReplies: 0Last Post: 11-04-2008, 08:33 AM -
For Trade: WTT 2002 WS6 Wheels/Tires + Cash For Your Wheels
By Zaccagnini in forum Parts For Sale / TradeReplies: 0Last Post: 11-04-2008, 08:32 AM -
I Need 2 Firehawk Wheels, Or a Place To get Wheels Rechromed!!
By cheetoh in forum Texas MembersReplies: 0Last Post: 06-17-2007, 09:32 PM -
will center caps off my factory ss 10 spoke wheels fit on zo6 wheels ?
By Speedy_Gonzales in forum Wheels and TiresReplies: 8Last Post: 04-01-2007, 09:06 AM -
4 Stock 16" Trans Am wheels and 2 WS6 Wheels
By Trans Am in forum Parts For Sale / TradeReplies: 2Last Post: 06-16-2006, 09:39 AM
