Results 1 to 11 of 11
Thread: question about wheels
02-22-2007, 12:36 AM #1Junior Member
- Dec 2006
- Michigan
Black- Formula... soon
what is the benefit for having these different sized wheels.
18x9.5 front and 18x10.5 rear? is there a disadvantage for this?
also does the c6 z06 have 18x9.5 all 4 tires?
what size wheels will be best for handling?
sorry for the retarded questions
02-22-2007, 07:51 AM #2
10.5 means you can have a wider back tire witch is better for traction
02-22-2007, 09:00 AM #3Firebird Encyclopedia
- Oct 2006
- St. Clair Shores. Michigan
Staggered wheel set ups are more for a look IMO
You may get added traction from wider rear wheels and tires.
The only downside is the inability to rotate the tires.Craig
Semi Retired Street Racer
Gone but not forgoten
NBM `98 Formula M6 HdTp
1 of 1 Build Date 3/12/98
02-22-2007, 09:07 AM #4King 0f n00bz
- Jan 2006
- Shepherd, Michigan
staggered wheels you also lose a lil bit for handling but not enough to shake a stick at
02-22-2007, 12:14 PM #5Junior Member
- Dec 2006
- Michigan
ok what size are the c6 z06. are they the same size all around?
im trying to figure out what the best size tires will be, mostly for handling. the f-body has an uneven weight balance... would that mean i would want slightly bigger tires in the rear for good handling? or just all the same size all around. and what size is best for handling?
02-22-2007, 10:15 PM #6fronts 18x9.5 and rears 19x11. they do look good on F-bodies thook what size are the c6 z06. are they the same size all around?
02-23-2007, 09:00 AM #7
moving to the right forum
02-24-2007, 11:12 PM #8Crazy Canuck !
- Jun 2002
- Montreal, CANADA
just get wide tires in the front allowing you to rotate.
Plus our cars tend to like same size tires f/r for handling... the car behaves well with wide in front.Eugenio_SS
02-25-2007, 11:32 AM #9
02-26-2007, 02:04 PM #10Crazy Canuck !
- Jun 2002
- Montreal, CANADA
the front was no problem, WAY easier than the rears.
with the stock brakes, i only needed to get a 7/32" spacer... some ppl use a 1/4" spacer.... the pix in the signature are w/ the 7/32" spacer.
no need to touch the fenders whatsoever... there is more room in the front than on the rear... check the 335 on all corners too
on 17x12... rear fender needed flaring, though.
02-26-2007, 06:47 PM #11
18x10.5 C5 Z06 wheels on 02 W6 question
By Whamhammer in forum Wheels and TiresReplies: 1Last Post: 07-08-2014, 07:41 PM -
QUESTION: Will Wheels Fit?
By SamD_Ind in forum Wheels and TiresReplies: 1Last Post: 07-10-2009, 11:17 AM -
question about the ten spoke ss wheels
By sosacorksthebat in forum Wheels and TiresReplies: 3Last Post: 05-05-2007, 08:54 AM -
C5 wheels-tire fit question on 96' TA??
By fordwhupper in forum Wheels and TiresReplies: 2Last Post: 03-04-2007, 04:26 PM -
Gotta question about Ws6 wheels
By BIGRED Z in forum Almost Anything GoesReplies: 1Last Post: 06-20-2006, 12:40 PM
