Results 1 to 16 of 16
Thread: What are these wires for?
10-05-2005, 08:00 PM #1
I was messing around with my plastic dash cover thingy that trims out the radio, a/c vents, and a/c controls. My car doesn't have the traction control but where the button should be ( next to the fog light switch ) there is the block off. But it still has wires that plug into the back of the block off. Could I just get a t/c switch and hook it up to make it work?
Thanks.
10-06-2005, 01:37 AM #2
just a spare wire
10-07-2005, 03:24 AM #3Are you sure your car doesn't have traction control? Some of these cars were built without the switch-my car was.I bought my 02 new and the window sticker said traction control-but there was no switch installed in the dash-just a block off plate.I already had a service manual from my 98 that I traded in so I knew what to look for mechanically to verify the system was there.Look underneath at the back axle-if there is a wire going to both back wheels instead of just going into the middle of the rear axle-you have traction control and all you need is the switch to turn it on and off.If you have traction control but no switch-it will be on all the time-you can't turn it off and it comes on automatically when you start the car.Anyway they ordered a switch and installed it-service guy said it happened from time to time,I said no harm no foul. The ABS module looks different also-but the easiest way to tell is looking at the back axle.
Originally Posted by blue02Z
10-07-2005, 04:50 AM #4
I would GUESS that GM uses generic wire harness, to cover all the options for the vehicles, so if your vehicle does not have traction control (as mine does not) they place a block off plate in front of the wire that would be used to connect it up.
SteveC
10-07-2005, 06:17 AM #5That would be my guess as well
Originally Posted by SteveC
10-07-2005, 07:30 AM #6quicky06Guest
kinda like my f250 i ordered it without a alarm and all they did was remove the fuse. lol al i had to do was put the fuse in and i had the alarm working
10-10-2005, 01:02 PM #7Junior Member
- Jul 2005
- oklahoma
I hate to say this, but the traction control option from the factory is not just a ABs thing, there is a ASR module that pulgs into the throttle body for the computer to physically move the gas pedal if needed.
All cars will tell you if the vehicle has low traction, even mine does and I do not have traction control at all. Any time the computer senses that the front wheels are traveling slower/faster than the rear wheels the low traction light will illuminate. This does not mean you ahve traction control.
10-10-2005, 03:57 PM #8
Originally Posted by Sneakyws6
OK-who said it was just a ABS thing? We were discussing how to tell whether you have the system installed on the car or not-not how does it work.I hate to tell you this -but it does more than that. The first thing it does is retard timing to reduce power from the engine.If the rear wheels are still spinning faster than the front it controls the throttle by wire to close the throttle.The last measure it takes is to apply the rear brakes(or just one brake) to reduce rear wheel spin.Once the rear wheel speed matches the front it will return control to the driver.The ABS will still alert you to low traction conditions under braking-but not under acceleration(according to the service manual).I mentioned the ABS because it looks different(they add a section to it)W/traction control-not because I thought that was all it did.
11-07-2007, 08:43 PM #9
So I should just be able to look in my dash behind the block off plate to see if it has the wires? i hope i dont have it...
11-08-2007, 03:49 AM #10
well i figured out that if you dont have the sensors in the hubs then you dont have traction control. it is just a generic wiring harness gm used
. gosh dang i forgot how long ago i started this thread
11-08-2007, 06:30 AM #11
Even if your car does not have TCS, the wiring harness will still be there!
11-19-2007, 05:32 PM #12Junior Member
- Nov 2007
- philadelphia
Black- 1996 Impala SS
Hi everybody, new member. I have decided to trade in my 96 Impala SS for a Camaro. I fell in love as soon as I drove my buddy's 00 SS. I found a 2000 SS for sale with a 6 speed. I just noticed that it doesn't have traction control. I am coming from a 96 Impala which is tail happy as anything in the rain/snow and it only has the LT1. I barely drive it in the snow, so that's not really an issue, but the rain is. My questions are: do I really need TCS on an LS1 car and can I add TCS without too much difficulty if I decide I need it?
11-20-2007, 04:56 AM #13
i have had mine for 3 1/2 years with no problem yet without TC. it helps but i dont think you need it tho. it will get tail happy tho, even in the dry pavement.
BTW- welcome on here
11-20-2007, 05:30 PM #14Junior Member
- Nov 2007
- philadelphia
Yeah, driving my friend's '00 let me find out how far sideways these cars can go. He swears by T/C in the rain.
Thanks, glad to be here.Last edited by Bowtie9496; 11-20-2007 at 05:54 PM.
11-21-2007, 11:28 PM #15
So do we have a concrete answer to the TC w/out button question? I'm curious... is there not an RPO code we could check rather than searching for wires on the axle?
11-28-2007, 01:17 PM #16Junior Member
- Nov 2007
- philadelphia
RPOs from another post:
NW7 : TRACTION CONTROL - ELECTRONIC
NW9 : TRACTION CONTROL - ELECTRONIC
Question: What should I do with the wires??
By blackSS01 in forum Computer & TuningReplies: 7Last Post: 04-12-2010, 06:59 PM -
Plugs and Wires Install...MSD wires E3 plugs
By Demon_Z28 in forum External EngineReplies: 13Last Post: 05-04-2008, 03:53 AM -
Help: Wires!!
By airmaxon1 in forum General HelpReplies: 2Last Post: 04-07-2008, 04:57 AM -
msd 8.5 wires
By silverz28camaro in forum External EngineReplies: 25Last Post: 10-20-2006, 03:36 PM -
She ate my MSD wires
By Breech in forum LT1Replies: 9Last Post: 08-18-2006, 03:15 PM
