02-20-2007, 08:04 PM #1Junior Member
- Dec 2006
- Alabama
Black- 98 Camaro SS
DTC code 1404?-EGR Valve,what gives?
Today had the local Advance Auto Parts read my SES code,1404 pops up,they couldn't help so I checked the net and it's one of two.
EGR Valve closed Pintle Position or
EGR Valve Stuck Open or Circuit Performance
Car is running fine with no misses or bad idles. Until I can get it looked at was wondering if anyone else seen this and did you have to replace EGR or was there a "quick fix" LOL
02-21-2007, 03:45 AM #2
change the valve?
Basically according to my 2000 GM Service Manual. If the voltages are good to the EGR Valve and Pintle remove the EGR valve and check for debris that is interfering with the valve movement. If that doesn't correct the condition change the valve.
02-21-2007, 05:56 PM #3Junior Member
- Dec 2006
- Alabama
Black- 98 Camaro SS
EGR problem
OK, thanks LX, I'll check that
02-23-2007, 07:33 AM #4
Pull it off and clean it. Probably has some carbon stuck in the pintle. I used to have this happen to an old blazer I had.
02-24-2007, 04:08 PM #5Junior Member
- Dec 2006
- Alabama
Black- 98 Camaro SS
EGR problem
OK, thanks for the info
JEGS stud mount valve spr. compresor vs. Speeds valve spring
By JehalinTA in forum Internal EngineReplies: 0Last Post: 05-30-2011, 06:16 AM -
D-Port Head Valve Upgrade - Big-Valve Performance on a Small
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 04-20-2011, 05:10 PM -
Valve cover gaskets, Valve Springs, Timing Gasket
By Dewman in forum Parts For Sale / TradeReplies: 0Last Post: 01-22-2010, 09:14 PM -
p-1404 code...... whats wrong?!
By DADillac in forum General HelpReplies: 6Last Post: 10-27-2006, 05:34 PM -
Can anyone tell me what code 1404 is?
By Marc '99T/A in forum Computer & TuningReplies: 1Last Post: 09-26-2005, 09:18 AM
