Results 1 to 20 of 23
    Junior Member Jessie's Avatar
    Aug 2006
    Stockton, CA
    1999 SS Camaro
    What shocks do you guys recommend???
    I have an 99 ss camaro and my car rides like a piece of crap... its time for sum new shocks... but i dont kno wut kind to get...
    DFW
    '18 CTS-V
    '13 ZL1
    doing great on reading until i got to the last 1/2 of your post...
    look into Blisteins, those were an option for the SS's. also there are KYB, and Koni's...
    2013 ZL1: °°590rwhp/576rwtq°°
    Konis are the best if you want to spend the money on them.
    Painted manta stripe
    Jenks/Tulsa
    Light Pewter Metallic
    y2k 8-cylinder catfish
    Deffinately go with Konis if you don't mind dropping the coin on them.
    2000 Chevrolet Camaro Z28 A4 - Light Pewter Metallic
    Direct Flo lid, SLP Loudmouth, Bassani Offroad Y-Pipe, BMR strut tower brace, BMR subframe connectors, shift points tune and !EGR
    2011 Kia Forte EX A6 Sportmatic - Titanium Silver Metallic
    STL,MO
    how come they dont make 70/30's for ls1's?
    +2
    Jun 2002
    Montreal, CANADA
    triple-black
    2000 CamaroSS convertible
    before just spending a lot onf $ on a great piece of equipment such as a Koni SA or Koni DA, let's see what you have as present suspension setup and see which shock will serve you better... who knows... there might be great shocks for the springs you have @ better $.
    Eugenio_SS
    Aug 2006
    Stockton, CA
    1999 SS Camaro
    well i was looking into the bilstein shocks, but then again i was told that the kyb shocks were also a great upgrade.....
    Jun 2002
    Montreal, CANADA
    triple-black
    Quote Originally Posted by Jessie View Post
    with all due respect, the kyb shocks aren't great, neither for handling nor confort. they are good mainly for drag purposes.
    but before we go on the shock of choice, we would like to know which springs you are using and swaybars.
    Is the rest of your suspension stock ? any mods ? please list them so we can help you better.
    Member rickssz's Avatar
    Feb 2006
    pgh
    I thought comp engineering made a 3 way adj that would go 70/30?
    Berkeley, CA
    2000 Camaro SS #3574 A4
    I'd also like to know which ones I should buy. I have SLP 3 point SFC's and a SLP STB. that's it for right now. which kind of shocks should I get?
    Jun 2002
    Montreal, CANADA
    triple-black
    keeping stock springs, you can go with Bilstein HD and see an amazing improvement... or go Koni SA in the front w/ Bilstein HD in the rear if you want to lower the car 3/4" due to Koni SA dual-perch location... while keeping stock springs.
    Berkeley, CA
    Quote Originally Posted by Eugenio_SS View Post
    hmm, well I want to keep the same ride height. I have the world's steepest driveway. the only time I don't scrape on it is if I'm going out in a 45 degree angle.
    Jun 2002
    Montreal, CANADA
    triple-black
    you can still go SA for the front and use the "stock location" perch setting.
    Bilstein HD will work very well on stock springs.
    Feb 2006
    pgh
    If you want just a good ride with good handling (better than stock) and no adjustment from what I read Bilstein HD @ app 350&up are the ticket. If you want adjustable and are afraid of KYB based on reviews the your lookin at 600 to 900 for Strange,QA1 or Koni. Sam Strano could valve you a special set for Im guessing 3to400 non adj.
    Berkeley, CA
    are you saying just new shocks for the front?
    Aug 2006
    Stockton, CA
    1999 SS Camaro
    Well currently, My car has stock springs,shocks, and swaybars all around.
    Jun 2002
    Montreal, CANADA
    triple-black
    no... I'm saying that you could go Koni SA in front and Bilstein HD in the rear.
    if going with that setup, you can actually lower the car by 3/4" by using the lower perch location of the Koni SA (it has 2 perch locations)
    the rear can be lowered by same amount using the hose-mod.
    rear stock shocks are a POS
    Berkeley, CA
    sounds good to me. how much are they?
    Jun 2002
    Montreal, CANADA
    triple-black
    call a vendor, such as Sam from http://www.stranoparts.com
    he has great advice and prices.
  1. recommend me good shocks for my application?
    By Zboner in forum Suspension and Handling
    Last Post: 09-19-2010, 09:10 AM
  2. what do you recommend
    By Firebirdformula in forum Drivetrain
    Last Post: 06-02-2009, 09:57 PM
  3. Recommend Cheap struts/shocks to go with Eibach SL
    By 5abivt in forum Suspension and Handling
    Last Post: 05-15-2009, 11:35 AM
  4. What do you guys recommend?
    By supersport00 in forum Almost Anything Goes
    Last Post: 08-05-2008, 08:14 PM
  5. do u guys recommend the b&m ripper shifter???
    By camarossf650 in forum Manual Transmission
    Last Post: 08-16-2007, 11:49 AM
