--Billingsly HVAC delete plate $60 retail, asking $45
Suspension/Steering:
--PA Racing Tubular K-member with solid motor mount, and pinto style steering rack brackets Chrome-Moly (powdercoat black) (brand new, bolted to engine on engine stand) $490 retail, asking $425
--PA Racing Tubular Lower A-arms with heim joints, Chrome-Moly (powdercoat black) (brand new, never used) $495 retail, asking $450
--PA Racing Tubular Upper A-arms with heim joints, Chrome-Moly with new Ball Joints (powdercoat black) (brand new, never used) $350 retail, asking $320
--Hal/QA1 front Shocker R series 12 way adjustable shocks (~4,000 miles) $370 retail, asking $300
--Hal/QA1 front Drag Race springs (~4,000 miles) $100 retail, asking $75
--Hal/QA1 front bearing kit (for adjusting ride height) (~4,000 miles), included with front/rear suspension. ~$50 retail
--Hal/QA1 rear 12 way adjustable shocks (~4,000 miles) $300 retail, asking $225
--Stock V6 rear springs
--Spohn tubular LCA’s with heim joints front/rear (powdercoat black) (~4,000 miles) $275 retail, asking $200
--Spohn tubular PHR with heim joints on both ends (powdercoat black) (~4,000 miles) $200 retail, asking $150
--Spohn adjustable Torque Arm (heavy duty) with heim joint on the front, and driveshaft safety loop (powdercoat black) (~4,000 miles) $565 retail, asking $475
--PA Racing (Flaming River) manual Pinto Steering Rack with tie rods and steering wheel linkage (brand new, never used) $490 retail, asking $425
Brakes:
--Strange Billet Drag Race Brakes (front) (brand new, still in box) $980 retail, asking $900
--Strange Billet Drag Race Brakes (rear) (brand new, still in box) $580 retail, asking $500
--Bearing Spacer kit (brand new, still in box) $35 retail, asking $25
--Rear SS Braided brake lines with adapters to stock hardlines, $75 retail, asking $60
--Strange Master Cylinder with Billingsly adapter to fit stock firewall (brand new) $200 retail, asking $180
--Summit Line Lock (Hurst style with black solenoid and nickel barrel (brand new) $70 retail, asking $50
Exhaust:
--Kooks LT1 1 3/4”- 1 7/8” step headers with 3.5” collectors (stainless steel) (brand new, never used, bolted to engine on engine stand) $1015 retail, asking $850
--Aerospace V-style flanges and clamps 3.5” (4 units) for exhaust fabrication stainless steel) (brand new, still in box) $250 retail, asking $200
--Mufflex 4” catback with Borla XR-1 muffler and single exit (hidden) turndown (used) $600 Retail, asking $400
--Flowmaster 4” Big Block muffler (new, never used) Included with above exhaust
Nitrous System:
--NOS black metal bottle brackets $45
--Blow down hose with fittings attached to trunk floor with a bulkhead fitting $75+
--NOS bottle heater element $85
--NOS 15# Hi-Flo bottle with pressure gauge (needs blow off valve disk) $215
--Dyno Tune nitrous bottle heater switch (pressure) mounted IN bottle) $50
--Nitrous Express dual/twin Shark Nozzles in Trick Flow (black crinkle coat) elbow $120 for nozzles, $82 for elbow
--Nitrous Express IceMan .125 orofice Nitrous Solenoid $135
--Nitrous Express Fuel Solenoid $95
--Nitrous Express Purge Solenoid/system $110
--NOS -6an nitrous filter $46
--NOS -4an nitrous filter $46
--NOS -4an feed line (from bottle in trunk to solenoids) $48
--NOS -6an feed line (from bottle in trunk to solenoids) $68
--Custom ~3/4 gallon aluminum fuel cell in place of stock battery $300
--Holley Blue pump with regulator and gauge $150
--Return style fuel system with jet for restriction $50
--Earl’s -8an fuel filter $40
--Misc braided line and fittings to make stand alone fuel system function $500++
Complete Nitrous/Fuel system cost approximately $2,000, asking $1,300, used 4 or 5 times on the dyno.
Engine Accessories: (Hope to sell with motor...)
--Taylor custom length plug wires (black, not yet cut) ~$50
--Made For You Loom (black/aluminum) ~$75
--SJM Low mount Alternator bracket/system (brand new, mounted to engine) $200 retail
--42# Lucas injectors (10,000 miles) $375
--AS&M Monoblade TB with “custom” black plastic top plate (for stealth…) $550
Located in Lincoln, CA 95648 (near Sacramento)
Contact Brian
[email protected]
(707) 480-7275
Please contact www.norcal-ls1.com and any member or officer for verification of my credibility and integrity.
