Results 1 to 20 of 21
    S. Florida
    98 Formula /93 Z28
    Rear end girdle.
    Hey guys I am rebuilding the 10 bolt in my Formula. It has 97,000 miles on it and it's noisy and showing wear. I just got a new Auburn differential that was an SLP takeout. I am also going to get a new set of Motive 3:42's and the Ratech complete kit with all the seals, bearings, etc. I know I would be better off with a 12 bolt or 9" but I don't have the cash for it. I got a great deal on the diff. and hopefully will be around $400 in parts for everything to make the rear as good as new (which we all know isn't too great) which is why I am staying with the stock gear ratio. My ? is will a TA rear end girdle really make a difference in strength for the rear?
    Feb 2007
    california
    blk
    well the way the girdle works is by reducing bearing cap flex........they look like they are legit...BUT. that in no way means the rearend will be strong enuff for any more power.........how much rwhp do you push ....id say 400 rwhp is goint to break that rear no matter what......even a hard 2nd gear shift would blow the 7.5 by then.....if your going to build this rear, as precaution weld the axle tubes also...get stock ratio 3.42 gears(last alot longer)
    you said you bought an eaton...awesome....do all these things and break the gears in right..and 400 rwhp will be held pretty well as long as you dont dump the clutch with drag radials.....also the suspension bind will make the 10 bolt flex and your gears will break(pinion deflection) so get some control arms and such.....
    hope this helps...
    Rollo Tomassee AKIRA's Avatar
    Outside the box
    He said he got an Auburn.
    S. Florida
    98 Formula /93 Z28
    I did get an Auburn. As for the gears I did also say I was staying with 3:42's. I have made the 4:10's in a 10 bolt mistake and wont do it again. I am just looking for a way to make the rear as strong as possible. I dont expect to make 3000rpm launches on ET streets or anything. Right now the car is bone stock so it is making probably around 300rwhp. At about the same time I do the rear I will be adding long tubes, TD's, and a lid but I should still be under 350 or right around it. I figure with the rebuilt rear I should hopefully be able to get the occasional trip to the track without problems as long as I don't use anything stickier than Nittos. Now once I get a cam I may be asking for trouble.
    Outside the box
    I am waiting for someone to come on in here and say to just get a 12-bolt.
    I just rebuilt my rear end. Ive got the Eaton (clutch driven) differential, TA Rear End Cover, Richmond 373 gears, Ratech Install Kit, and "Axle Savers." Thats about as strong as you can get, but if I am going to keep the car, I will continue to modify it and all this shit will have to be replaced. Its going to happen. Or I will sell my car, but no matter what, one of those options will occur.
    Where is S. Florida do you live? Do you know of ANY speed shops that dyno tune? I need a tune bad. I live 45 min N of West Palm Beach.
    ls1devil lt1dragon's Avatar
    Utah
    1999 ls1
    I have a T/A girdle when i had my 3.73 gears put in the shop said they are worth the money so i had one installed.
    S. Florida
    98 Formula /93 Z28
    Quote Originally Posted by AKIRA View Post
    I am in Port St. Lucie. I don't know of anyone locally that dyno tunes.
    doylestown, Pa
    SILVER
    2004 CTS-V
    He said he doesn't have the money for a 12 bolt or 9". Besides, alot of guys get lucky and get a good amount of use with the 10 bolt. I had 136,000miles of massive abuse on mine, and it took it well.
    Outside the box
    Hah im in stuart.
    S. Florida
    98 Formula /93 Z28
    I figured you must be close when you said you were 45 mins N of West palm. You must drive slow I am north of you and it takes me 45 minutes too
    S. Florida
    98 Formula /93 Z28
    I'm hoping it holds up pretty decent. All in all I should only have about $500 or so of parts in it when all is said and done. Much cheaper than well over $2000 for a 12 Bolt, 9 inch or S60. I have known many guys who put literally hundreds of passes on the 10 bolt w/ 3:42's and an M6 that were in the high to mid 12's. That is about where I would like my car to be for the forseeable future. When it doesn't need to be my daily driver anymore (I drive 90-100 miles a day) then I may swap the rear.
    Feb 2007
    california
    blk
    i was consistently running low 12's on my fully built 10 bolt-m6 combo...and that's when i was consistently busting ring and pinion gears....and eventually blowing out aftermarket diffs....
    and a fully built 10 bolt can easily be broke with stock hp. and dr's
    doylestown, Pa
    SILVER
    2004 CTS-V
    Quote Originally Posted by stunna-shades View Post
    Yeah, we all know that there is a limit to what they can handle, but for the most part they are sufficiant. Yes, it would be money well spent buying a 12 bolt or such, but their damn expensive!
    Feb 2007
    california
    blk
    definately..if you want full potential from your f-body..otherwize a built 10 bolt should be fine
    Member lrader99's Avatar
    NW Georgia
    flat black
    welding the axle tubes is a really good idea but make sure they put the rear in a jig...when you weld it gets the metal hot and prone to distort...the last thing you want is warped axle tubes....but on the subject of the girdle i am running a TA girdle its much thicker than the factory piece which on top of it being stronger it also helps absorb the heat in the rear end...aluminum cools much faster than steel.
    Feb 2007
    california
    blk
    the aftermarket covers also hold more fluid,which would dissipate more heat..so if not just for that reason
    Outside the box
    Thats actually the only real reason why I thought they were beneficial. I mean, does have the "stoppers" in them too, but are they really that effective?
    doylestown, Pa
    SILVER
    2004 CTS-V
    Yes, it puts a load on the caps
    Feb 2007
    california
    blk
    its not a big diffrence but every little thing helps
    Marylandistan
    2001 Trans Am (sold)
    I dont really think it helps much, looks cool tho.
  1. REAR end girdle
    By tonyjnjz in forum Drivetrain
    Last Post: 09-01-2008, 07:53 AM
  2. Which rear end girdle is best?
    By Mr. Hyde in forum Drivetrain
    Last Post: 06-10-2007, 04:34 PM
  3. T/A rear end girdle?
    By Z28LS1 in forum Drivetrain
    Last Post: 04-14-2007, 12:49 PM
  4. rear end girdle
    By silverz28camaro in forum Drivetrain
    Last Post: 03-13-2007, 01:11 PM
  5. Rear end girdle...
    By Mr. Luos in forum Drivetrain
    Last Post: 05-23-2006, 02:19 PM
