Thread: Applying retro emblems
02-15-2007, 10:39 AM #1
I was thinking about getting some 69 z/28, blue bowtie, and camaro emblems. What is the best way to put them on without drilling holes? I was thinking cutting off the mounting tabs and seeing if i could find some think double sided tape and cut them to fit. Any other ideas or suggestions?
02-15-2007, 10:49 AM #2
Yes two sided 'car trim tape' will do the trick.
02-28-2007, 08:30 PM #3
They make a special glue for that as well.
03-01-2007, 06:52 AM #4
I've used both, 3M automotive emblem tape and Automotive Goop.
The tape works fine if you've got a good surface area, but for things like Scripts, you'll need the goop. Personally I think that Goop is more permanent as well, so consider that.
And to get those studs off of the emblems, just use a cut off wheel and then grind it flat, with a lot of the emblems the backing is recessed; I find it helpful to use liquid steel or other metal epoxy to make the back flush, then go from there.She's baaaaaccccck...
'02 Z/28 M6 Hardtop
Patent making, applying, understanding Help Needed
By Hi-Po in forum Almost Anything GoesReplies: 9Last Post: 05-28-2010, 02:14 PM -
You applying for finanical aid? Come in!
By AKIRA in forum Almost Anything GoesReplies: 3Last Post: 04-14-2008, 06:23 PM -
Retro Z/28 Emblems *Pics*
By Neenjah in forum Camaro / SSReplies: 15Last Post: 06-29-2007, 09:46 AM -
theoretically: rain while applying wax?
By third_shift|studios in forum Showcar and DetailingReplies: 9Last Post: 08-22-2006, 01:10 PM -
Applying Polish
By Too Slow in forum Showcar and DetailingReplies: 6Last Post: 01-20-2006, 05:19 PM
