Results 1 to 16 of 16
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    NX intake, NXL DP system, 85MM TB
    just got it in today. normally, this kit would have nozzles that go under the fuel injector. i got their LS intake that has the ports drilled into the intake for the nitrous and fuel.
    the intake
    here's a close up of where the nitrous lines will go to just like if you had a nozzle.
    here's what it looks like inside the injector hole where the nitrous and fuel will come out
    the underside of the intake has a 1/4" thick aluminum plate
    inside the intake
    the NXL direct port kit replaces the factory LS intake fuel rails. this way, it pulls fuel right off the rails
    the fuel accumulator. this helps with the initial hit of the system.
    the 85mm TB
    orlando, fl
    2014 camaro 2ss/rs
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    IT'S A GREAT SET-UP!!! WAIT TILL YOU FEEL THE DIFFERENCE IN THE INTIAL HIT OUT THE GATE!!!! EVEN WITH 100 HP JETS I BEAT YOU'LL RUN THE SAME ET'S AS WITH 175 JETS ON THE OLD UNIT.
    Josh had me try out some some passes like that and I was amased!!!
    You'll love it!!!!
    Arkansas
    99 Trans Am
    wow.... thats really all I can say.
    Price?
    orlando, fl
    2014 camaro 2ss/rs
    intake 850.00
    TB - 525.00
    NXL - 1200.00
    accumulator - 200.00
    total 2725.00
    a little less because with the intake, you don't need the NXL nozzles that would come with the NXL kit if you bought it complete.
    Arkansas
    99 Trans Am
    more than my head/cam swap!! wow.. very nice setup though. I cant wait for you to post your results with it.
    Member 1SSWFO's Avatar
    RIGHT BESIDE THE LEMON TREE IN HELL!!!
    LIGHT PEWTER METALIC
    1999 SS CAMARO
    sweet setup! I got the nxl kit sitting in the old garage sort of waiting on some help to put it on. any suggestions on: whether stock fuel pump and stock injectors will work for now? and since i put the LT's ORY, FAST 90 Intake and 90 TB I haven't had it tuned? good-bad?
    orlando, fl
    2014 camaro 2ss/rs
    i've had the stock fuel pump up to 482 rwhp on a 150 shot. that was on the wife's car with heads, cam, the works. did you get the accumulator as well?
    1999 SS CAMARO
    NO BUT DO i REALLY NEED IT?
    orlando, fl
    2014 camaro 2ss/rs
    the accumulator is there to make up for the initial hit of the NXL system. most have experienced the vehicle nosing over on the inital activation due to the sudden pull on the fuel rails. once the fuel pump refills the rails, then it's fine. we are talking about less than a half second delay. only way to find out is install it and see if the nose over is bad enough to warrant one.
    d
    2002 z28
    thats a sweet set up
    orlando, fl
    2014 camaro 2ss/rs
    yes it is.
    Member transam98's Avatar
    Herrin, IL
    2003 Ram 2500
    May I ask where you bought all that stuff from?
    orlando, fl
    2014 camaro 2ss/rs
    NX direct. talk to ricky.
    Herrin, IL
    2003 Ram 2500
    OK thanks Im just wanting to get back into a trans am as soon as I get out of basic. I was looking at that setup when I had my first trans am. Can you give me any feedback on it?
    orlando, fl
    2014 camaro 2ss/rs
    the only feedback i can give you at this time is all the pieces are of really high quality. only minor things are i had to modify the fuel rail brackets and grin down the access plate to clear the LS6 valley cover where the PCV hose barb comes out at.
  1. ls6 intake & 85mm tb
    By Ls1fury in forum Parts For Sale / Trade
    Last Post: 11-18-2009, 12:19 PM
  2. 85mm bbk intake, do i need 85mm throttle body?
    By jmatt07 in forum External Engine
    Last Post: 02-13-2009, 07:15 AM
  3. NX intake, 85mm TB, NXL system for sale
    By mrr23 in forum Nitrous
    Last Post: 07-27-2008, 08:00 AM
  4. Professional Products 85mm Typhoon Polished Intake/85mm TB
    By 1QuikWS6 in forum Parts For Sale / Trade
    Last Post: 09-18-2007, 12:40 PM
  5. NEW NX 1-Pc 85mm MAF Nitrous System-Super Complete!
    Last Post: 08-21-2007, 07:23 PM
