Thread: Ign Tumbler Replacement Vats
02-10-2007, 09:58 PM #1Junior Member
- Dec 2006
- Chino Hills, Ca
Black- 98 WS6
Read about everything I could find on the vats issues.
Cleaned, re-clean, had new keys made. All 4 keys worked in series, then 20 mins later no luck again
So, how do you replace the ign tumbler. I could not find a how to in my searches.
Can I just by one at Autozone, or do I need to do something special, matched set from the dealer?.
I looked at some bypass diagrams, to make life easier for the time being. It looks like you just disconnect the plug and stick the resistor into the Vats side..is that right?. Not sure how it works if the wires are cut completely. But maybe it does. The Diagram and the under dash pic on shoebox, seam to be saying something different. I am confused.
Any help would be great.
1. how to replace the tumbler
2. do I need to buy the tumbler from the dealer and another new key to match.
3. Help me understand the bypass question I have above.
Thanks
02-11-2007, 01:08 PM #2Junior Member
- Dec 2006
- Chino Hills, Ca
Black- 98 WS6
Anyone?
02-11-2007, 01:17 PM #3Junior Member
- Jan 2007
- Glendale az
I'm confused. I'm not familiar with the vats thing
so is your ign switch messed up or something?
You can get a tumbler from just about anywhere. It should come with a key... unless you have a sentry key, which you'll have to go to the dealership for
02-11-2007, 01:21 PM #4Senior Member
- Jul 2005
- Jacksonville, FL
Is the shoebox diagram you were looking at? Should work with the right key pelet value. http://shbox.com/1/vats_bypass.jpg
02-11-2007, 05:29 PM #5Junior Member
- Jan 2007
- Glendale az
oh so you want to bypass the sentry key. lol. learn something new everyday
02-15-2007, 11:42 PM #6
Basically, you measure the resistance of the pellet in your key then buy resistors to match. I cut my wires on the column side of the plug then soldered 2 resistors in a series together then soldered those to the plug and plugged it back in. Piece of cake to do.
Need to change ignition tumbler, key getting loose hard to s
By xlor8923 in forum Camaro / SSReplies: 3Last Post: 08-30-2016, 08:35 AM -
Help: 3rd gen VATS
By 2000dreambird in forum General HelpReplies: 2Last Post: 08-05-2013, 10:14 PM -
Vats?
By shaggsm3ls1 in forum Computer & TuningReplies: 2Last Post: 05-02-2011, 01:36 PM -
difference between ign lock cyl and tumbler?
By flyinlo28 in forum General HelpReplies: 3Last Post: 07-29-2010, 06:20 PM -
VATS????Security problem with the VATS.
By LS1RacerMan30 in forum General HelpReplies: 14Last Post: 07-14-2007, 07:39 AM
