Results 1 to 3 of 3
    d
    2002 z28
    VOLT gauge is almost at red need help?
    my volts are ready pretty high all the time at start and at stop. when i bought it it had a red top optiama if that helps.
    Senior Member
    Jacksonville, FL
    I have an optima in mine and never goes past the 3rd mark on the gauge on a cold start - then slowly falls back to just over 13. If it's going into the red on the high side and staying there sounds like a possible voltage regulator (alternator) problem. Most local auto parts stores will check the battery and charging system for free.
    d
    2002 z28
    thanks
  1. Volt Gauge?
    By pajeff02 in forum GM Trucks
    Last Post: 11-19-2010, 10:22 AM
  2. Wanted: Boost/Vac,Volt, and AF gauge
    By ocshaman in forum Parts Wanted / Trade
    Last Post: 07-07-2008, 03:16 AM
  3. Volt gauge
    By GNICTRY in forum General Help
    Last Post: 10-08-2007, 04:45 AM
  4. BOOST gauge, FUEL PRESSURE gauge, dual pillar pod
    By onefastbird! in forum Parts Wanted / Trade
    Last Post: 04-26-2007, 08:31 PM
  5. 16 Volt ?'s
    By wildkatz in forum Stereo and Electronics
    Last Post: 06-26-2006, 09:59 PM
